Datasheet ADA4528-2-EP (Analog Devices)
Description | Precision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp |
Pages / Page | 17 / 1 — Precision, Ultralow Noise, RRIO,. Zero-Drift Op Amp. Enhanced Product. … |
File Format / Size | PDF / 661 Kb |
Precision, Ultralow Noise, RRIO,. Zero-Drift Op Amp. Enhanced Product. ADA4528-2-EP. FEATURES. PIN CONNECTION DIAGRAM
Precision, Ultralow Noise, RRIO, Zero-Drift Op Amp Enhanced Product ADA4528-2-EP FEATURES PIN CONNECTION DIAGRAM Low offset voltage: 2.5 µV maximum ADA4528-2-EP TOP VIEW Low offset voltage drift: 0.015 μV/°C maximum (Not to Scale) Low noise OUT A 1 8 V+ 5.6 nV/√Hz at f = 1 kHz, A = +100 V –IN A 2 7 OUT B 97 nV p-p at f = 0.1 Hz to 10 Hz, A = +100 V +IN A 3 6 –IN B Open-loop gain: 130 dB minimum V– 4 5 +IN B CMRR: 135 dB minimum PSRR: 130 dB minimum NOTES
107
1. CONNECT THE EXPOSED PAD TO Unity-gain crossover: 4 MHz V– OR LEAVE IT UNCONNECTED.
14897-
Gain bandwidth product: 3 MHz at A = +100
Figure 1.
V −3 dB closed-loop bandwidth: 6.2 MHz Single-supply operation: 2.2 V to 5.5 V 100 Dual-supply operation: ±1.1 V to ±2.75 V VSY = 5V Rail-to-rail input and output (RRIO) AV = 1 z) VCM = VSY/2 Unity-gain stable √H V/ ENHANCED PRODUCT FEATURES (nYT SI Supports defense and aerospace applications (AQEC standard) EN 10 Extended industrial temperature range: −55°C to +125°C ISE D Controlled manufacturing baseline O E N 1 assembly/test site G A 1 fabrication site LT VO Product change notification Qualification data available upon request 1 APPLICATIONS 1 10 100 1k 10k 100k 1M 10M
063
FREQUENCY (Hz)
14897-
Thermocouples/thermopiles
Figure 2. Voltage Noise Density vs. Frequency
Load cell and bridge transducers Precision instrumentation Electronic scales Medical instrumentation Handheld test equipment GENERAL DESCRIPTION
The ADA4528-2-EP is an ultralow noise, zero-drift operational which make it ideal for applications that require precision amplifier featuring rail-to-rail input and output swing. With an amplification of low level signals, such as position and pressure offset voltage of 2.5 μV, offset voltage drift of 0.015 μV/°C, and sensors, strain gages, and medical instrumentation. typical noise of 97 nV p-p (0.1 Hz to 10 Hz, AV = +100), the The ADA4528-2-EP is specified over the extended industrial ADA4528-2-EP is well suited for applications in which error temperature range (−55°C to +125°C) and is available in an 8-lead sources cannot be tolerated. LFCSP package. The ADA4528-2-EP has a wide operating supply range of 2.2 V to Additional application and technical information can be found 5.5 V, high gain, and excellent CMRR and PSRR specifications, in the ADA4528-2 datasheet.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
