DatasheetsDatasheet ADA4897-1-EP, ADA4897-2-EP (Analog …
Datasheet ADA4897-1-EP, ADA4897-2-EP (Analog Devices)
Description | 1 nV/√Hz, Low Power Operational Amplifier |
Pages / Page | 12 / 1 — 1 nV/√Hz, Low Power,. Rail-to-Rail Output Amplifiers. Enhanced Product. … |
File Format / Size | PDF / 364 Kb |
1 nV/√Hz, Low Power,. Rail-to-Rail Output Amplifiers. Enhanced Product. ADA4897-1-EP/. ADA4897-2-EP. FEATURES. Low wideband noise
1 nV/√Hz, Low Power, Rail-to-Rail Output Amplifiers Enhanced Product ADA4897-1-EP/ ADA4897-2-EP FEATURES
The ADA4897-1-EP is available in 6-lead SOT-23 package and the ADA4897-2-EP is available in a 10-lead MSOP package. The
Low wideband noise
ADA4897-1-EP/ADA4897-2-EP operate over the extended
1 nV/√Hz 2.8 pA/√Hz
industrial temperature range of −55°C to +125°C. Additional
Low 1/f noise: 2.4 nV/√Hz at 10 Hz
application and technical information can be found in the
Low distortion: −115 dBc at 100 kHz, V
ADA4897-1/ADA4897-2 data sheet.
OUT = 2 V p-p Low power: 3 mA per amplifier FUNCTIONAL BLOCK DIAGRAM Low input offset voltage: 0.5 mV maximum ADA4897-1-EP High speed OUT 1 6 +VS −3 dB bandwidth: 230 MHz (G = +1) Slew rate: 120 V/μs –VS 2 5 DISABLE Settling time to 0.1%: 45 ns
101
+IN 3 4 –IN
48-
Rail-to-rail output
094
Wide supply range: 3 V to 10 V
Figure 1. 6-Lead SOT-23 (ADA4897-1-EP)
Disable feature 8 VS = ±5V ENHANCED PRODUCT FEATURES 7 Supports defense and aerospace applications (AQEC standard) ) 6 Extended industrial temperature range (−55°C to +125°C) √Hz Controlled manufacturing baseline V/ 5 1 assembly/test site ISE (n O 4 1 fabrication site E N Enhanced product change notification G 3 A T Qualification data available on request L O V 2 APPLICATIONS 1 Low noise preamplifier Ultrasound amplifiers 0
2
1 10 100 1k 10k 100k 1M 5M
10
PLL loop filters
8-
FREQUENCY (Hz)
944 0
High performance ADC drivers
Figure 2. Voltage Noise vs. Frequency
DAC buffers Table 1. Other Low Noise Amplifiers GENERAL DESCRIPTION VN (nV/√Hz) Supply
The ADA4897-1-EP/ADA4897-2-EP are unity-gain stable, low
Part No. At 1 kHz At 100 kHz BW (MHz) Voltage (V)
noise, rail-to-rail output, high speed voltage feedback amplifiers that AD797 0.9 0.9 8 10 to 30 have a quiescent current of 3 mA. With a 1/f noise of 2.4 nV/ AD8021 5 2.1 490 5 to 24 √Hz at 10 Hz and a spurious-free dynamic range of −80 dBc at AD8099 3 0.95 510 5 to 12 2 MHz, these amplifiers are ideal solutions in a variety of AD8045 6 3 1000 3.3 to 12 applications, including ultrasound, low noise preamplifiers, and ADA4899-1 1.4 1 600 5 to 12 drivers of high performance ADCs. The Analog Devices, Inc., ADA4898-1/ 0.9 0.9 65 10 to 32 proprietary next-generation SiGe bipolar process and innovative ADA4898-2 architecture enable such high performance amplifiers.
Table 2. Complementary ADCs
The ADA4897-1-EP/ADA4897-2-EP have 230 MHz bandwidth,
Part No. Bits Speed (MSPS) Power (mW)
120 V/μs slew rate, and settle to 0.1% in 45 ns. With a wide AD7944 14 2.5 15.5 supply voltage range of 3 V to 10 V, the ADA4897-1-EP/ AD7985 16 2.5 15.5 ADA4897-2-EP are ideal candidates for systems that require AD7986 18 2 15 high dynamic range, precision, low power, and high speed.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Enhanced Product Features Applications General Description Functional Block Diagram Revision History Specifications ±5 V Supply +5 V Supply +3 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Outline Dimensions Ordering Guide
