Datasheet ADA4858-3 (Analog Devices) - 2
DescriptionSingle-Supply, High Speed, Triple Op Amp with Charge Pump
Pages / Page21 / 2 — ADA4858-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 407 Kb
ADA4858-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADA4858-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADA4858-3 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADA4858-3 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADA4858-3 EngineerZone Discussions. • ADA4858-3: Single-Supply, High Speed, Triple Op Amp with Charge Pump Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-140: Universal Evaluation Board for Triple, High Speed Op Amps with Charge Pump Offered in 16-Lead, 4 mm × 4
TECHNICAL SUPPORT
mm LFCSP Packages Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS
• ADA4858 SPICE Macro Model
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Tutorials
• MT-034: Current Feedback (CFB) Op Amps • MT-051: Current Feedback Op Amp Noise Considerations • MT-057: High Speed Current Feedback Op Amps • MT-059: Compensating for the Effects of Input Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters
Document Outline Features Applications General Description Connection Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Overview Charge Pump Operation Applications Information Gain Configurations DC-Coupled Video Signal Multiple Video Driver DC Restore Function Clamp Amplifier PD (Power-Down) Pin Power Supply Bypassing Layout Outline Dimensions Ordering Guide
