link to page 6 link to page 6 link to page 6 Data SheetADA4858-3ABSOLUTE MAXIMUM RATINGSMAXIMUM POWER DISSIPATIONTable 3. ParameterRating The maximum power that can be safely dissipated by the Supply Voltage 6 V ADA4858-3 is limited by the associated rise in junction Internal Power Dissipation1 temperature. The maximum safe junction temperature for 16-Lead LFCSP See Figure 2 plastic encapsulated devices is determined by the glass transition Input Voltage (Common Mode) (−V − 0.2 V) to (+V − 1.2 V) temperature of the plastic, approximately 150°C. Temporarily S S Differential Input Voltage ±V exceeding this limit may cause a shift in parametric performance S Output Short-Circuit Duration Observe power derating curves due to a change in the stresses exerted on the die by the package. Storage Temperature Range −65°C to +125°C Exceeding a junction temperature of 175°C for an extended Operating Temperature Range −40°C to +105°C period can result in device failure. Lead Temperature 300°C To ensure proper operation, it is necessary to observe the (Soldering, 10 sec) maximum power derating curves in Figure 2. 1 Specification is for device in free air. 2.5 Stresses above those listed under Absolute Maximum Ratings ) may cause permanent damage to the device. This is a stress (W2.0N rating only; functional operation of the device at these or any IO T other conditions above those indicated in the operational PA1.5 section of this specification is not implied. Exposure to absolute ISSI D maximum rating conditions for extended periods may affect ER W device reliability. 1.0M POMU XI0.5MA0–40–20020406080100 002 AMBIENT TEMPERATURE (°C) 07714- Figure 2. Maximum Power Dissipation vs. Ambient Temperature ESD CAUTION Rev. B | Page 5 of 20 Document Outline Features Applications General Description Connection Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Overview Charge Pump Operation Applications Information Gain Configurations DC-Coupled Video Signal Multiple Video Driver DC Restore Function Clamp Amplifier PD (Power-Down) Pin Power Supply Bypassing Layout Outline Dimensions Ordering Guide
