Datasheet MAX4162, MAX4163, MAX4164 (Maxim) - 9
Manufacturer | Maxim |
Description | UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps |
Pages / Page | 13 / 9 — UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. … |
File Format / Size | PDF / 331 Kb |
UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. MAX4162/MAX4163/MAX4164
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps MAX4162/MAX4163/MAX4164 Typical Operating Characteristics (continued)
(VDD = 5V, VSS = 0V, VCM = VDD/2, TA = +25°C, unless otherwise noted.)
NONINVERTING LARGE-SIGNAL PULSE RESPONSE MAX4163/MAX4164 (VDD = 5V, CL = 1500pF) CROSSTALK vs. FREQUENCY
MAX4162-32 0 -20 IN MAX4162-33 2V/div -40 -60 -80 CROSSTALK (dB) -100 OUT 2V/div -120 -140 -160 100µs/div 0.1 1 10 100 1000 VDD = 5V, VIN = 4V, RL = 100kΩ to VDD/2, FREQUENCY (kHz) CL = 1500pF
Pin Description PIN MAX4162 MAX4163 MAX4164 NAME FUNCTION SO SOT23 SO/µMAX UCSP SO
1, 5, 8 — — — — N.C. No Connection. Not internally connected. 2 4 — — — IN- Amplifier Inverting Input 3 3 — — — IN+ Amplifier Noninverting Input 4 2 4 C2 11 VSS Negative Power Supply 6 1 — — — OUT Amplifier Output 7 5 8 A2 4 VDD Positive Power Supply — — 1 A1 1 OUTA Amplifier A Output — — 2 B1 2 INA- Amplifier A Inverting Input — — 3 C1 3 INA+ Amplifier A Noninverting Input — — 5 C3 5 INB+ Amplifier B Noninverting Input — — 6 B3 6 INB- Amplifier B Inverting Input — — 7 A3 7 OUTB Amplifier B Output — — — — 8 OUTC Amplifier C Output — — — — 9 INC- Amplifier C Inverting Input — — — — 10 INC+ Amplifier C Noninverting Input — — — — 12 IND+ Amplifier D Noninverting Input — — — — 13 IND- Amplifier D Inverting Input — — — — 14 OUTD Amplifier D Output
_______________________________________________________________________________________ 9
