1.3 Absolute maximum ratings. 1/ Supply voltage (VS) .. 22 V Internal power dissipation ... 500 mW Input voltage .. 22 V 2/ Output short-circuit duration .. Indefinite Differential input voltage .. 0.7 V 3/ Differential input current .. 25 mA 3/ Storage temperature range ... -65C to +150C Operating temperature range .. -55C to +125C Lead temperature (soldering, 60 seconds) .. +300C Junction temperature range (TJ) .. -65C to +150C Thermal resistance, junction-to-case (JC) .. See MIL-STD-1835 Thermal resistance, junction-to-ambient (JA): Cases G and H ... 150C/W Case P ... 119C/W Case 2 .. 110C/W 1.4 Recommended operating conditions. Supply voltage (VS) ... 4.5 V to 18 V Source resistor (RS) .. 50 Ambient operating temperature range (TA) ... -55C to +125C 1.5 Radiation features: Device type 02: Maximum total dose available (dose rate = 50 – 300 rads(Si)/s) ... 100 krads(Si) 4/ Device type 03: Maximum total dose available (dose rate 10 mrads(Si)/s) .. 50 krads(Si) 5/ _____ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ For supply voltages less than 22 V, the absolute maximum input voltage is equal to the supply voltages. 3/ The device inputs are protected by back-to-back diodes. Current limiting resistors are not used in order to achieve low noise. If differential input voltage exceeds 0.7 V, the input current should be limited to 25 mA. 4/ These parts may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions as specified in MIL-STD-883, method 1019, condition A. 5/ For device type 03, radiation end point limits for the noted parameters are guaranteed for the conditions specified in MIL-STD-883, test method 1019, condition D. STANDARD SIZE 5962-94680MICROCIRCUIT DRAWINGA DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 3 DSCC FORM 2234 APR 97
