Datasheet MCP3422, MCP3423, MCP3424 (Microchip) - 10
Manufacturer | Microchip |
Description | 18-Bit, Multi-Channel ΔΣ Analog-to-Digital Converter with I2C Interface and On-Board Reference |
Pages / Page | 58 / 10 — MCP3422/3/4. Note:. 200. Data Rate = 3.75 SPS. 180. DD = 5.5V. 160. t (. … |
Revision | 08-21-2009 |
MCP3422/3/4. Note:. 200. Data Rate = 3.75 SPS. 180. DD = 5.5V. 160. t (. ) A 140. r Drif. A 120. I DD. VDD = 2.7V. illa. 100. DD = 5.0V. O -1. -60. -40. -20
MCP3422/3/4 Note:
Unless otherwise indicated, TA = -40°C to +85°C, VDD = +5.0V, VSS = 0V, CHn+ = CHn- = VREF/2, VINCOM = VREF/2.
200 3 Data Rate = 3.75 SPS 180 ) V 2 DD = 5.5V % 160 t ( ) A 140 1 (µ r Drif A 120 to I DD 0 VDD = 2.7V illa 100 c V s DD = 5.0V O -1 80 60 -2 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature (°C) Temperature (°C) FIGURE 2-7:
IDDA vs. Temperature.
FIGURE 2-10:
Oscillator Drift vs. Temperature.
1 0 0.9 Data Rate = 3.75 SPS -10 0.8 -20 ) -30 0.7 V ) DD = 5.5V -40 0.6 (dB -50 (µA 0.5 de S -60 tu 0.4 V I DD DD = 5.0V -70 0.3 gni a -80 0.2 M -90 0.1 V -100 DD = 2.7V 0 -110 -120 -60 -40 -20 0 20 40 60 80 100 120 140
0.1 1 10 100 1000 10000
0.1 1 10 100 1k 10k Temperature (°C) Input Signal Frequency (Hz) FIGURE 2-8:
IDDS vs. Temperature.
FIGURE 2-11:
Frequency Response.
14 V 12 DD = 5.5V VDD = 5.0V 10 ) A 8 (µ B V 6 DD = 4.5V I DD 4 2 VDD = 2.7V 0 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature (°C) FIGURE 2-9:
IDDB vs. Temperature. DS22088C-page 10 © 2009 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics 2.0 Typical Performance Curves FIGURE 2-1: INL vs. Supply Voltage (VDD). FIGURE 2-2: INL vs. Temperature. FIGURE 2-3: Offset Error vs. Temperature. FIGURE 2-4: Output Noise vs. Input Voltage. FIGURE 2-5: Total Error vs. Input Voltage. FIGURE 2-6: Gain Error vs. Temperature. FIGURE 2-7: IDDA vs. Temperature. FIGURE 2-8: IDDS vs. Temperature. FIGURE 2-9: IDDB vs. Temperature. FIGURE 2-10: Oscillator Drift vs. Temperature. FIGURE 2-11: Frequency Response. 3.0 Pin Descriptions TABLE 3-1: PIN Function Table 3.1 Analog Inputs (CHn+, CHn-) 3.2 Supply Voltage (VDD, VSS) FIGURE 3-1: Equivalent Analog Input Circuit. 3.3 Serial Clock Pin (SCL) 3.4 Serial Data Pin (SDA) 3.5 Exposed Thermal Pad (EP) 4.0 Description of Device Operation 4.1 General Overview 4.2 Power-On-Reset (POR) FIGURE 4-1: POR Operation. 4.3 Internal Voltage Reference 4.4 Analog Input Channels 4.5 Input Voltage Range 4.6 Input Impedance 4.7 Aliasing and Anti-aliasing Filter 4.8 Self-Calibration 4.9 Digital Output Codes and Conversion to Real Values TABLE 4-1: Resolution Settings VS. LSB TABLE 4-2: Example of output code for 18 bits (Note 1, Note 2) TABLE 4-3: Minimum and Maximum Output codes (Note) TABLE 4-4: Example of converting output code to voltage (With 18 Bit Setting) 5.0 Using the Devices 5.1 Operating Modes 5.2 Configuration Register TABLE 5-1: Write Configuration Bits TABLE 5-2: READ Configuration Bits 5.3 I2C Serial Communications FIGURE 5-1: Address Byte. FIGURE 5-2: General Call Latch Command and Voltage Output at Address Pin Left “Floating” (MCP3423 and MCP3424). FIGURE 5-3: Timing Diagram For Writing To The MCP3422/3/4. TABLE 5-3: Output Codes of each Resolution OPTION FIGURE 5-4: Timing Diagram For Reading From The MCP3422/3/4 With 18-Bit Mode. FIGURE 5-5: Timing Diagram For Reading From The MCP3422/3/4 With 12-Bit to 16-Bit Modes. 5.4 General Call FIGURE 5-6: General Call Address Format. 5.5 High-Speed (HS) Mode 5.6 I2C Bus Characteristics FIGURE 5-7: Data Transfer Sequence on I2C Serial Bus. TABLE 5-4: I2c serial timing Specifications (Continued) FIGURE 5-8: I2C Bus Timing Data. 6.0 Basic Application Configuration 6.1 Connecting to the Application Circuits FIGURE 6-1: Typical Connection. FIGURE 6-2: Example of Multiple Device Connection on I2C Bus. FIGURE 6-3: I2C Bus Connection Test. FIGURE 6-4: Differential and Single- Ended Input Connections. 6.2 Application Examples FIGURE 6-5: Battery Voltage and Charging/Discharging Current Measurement. FIGURE 6-6: Four-Channel Thermocouple Applications. FIGURE 6-7: Example of Pressure and Temperature Measurement. 7.0 Development Tool Support 7.1 MCP3422/3/4 Evaluation Boards FIGURE 7-1: MCP3424 Evaluation Board. FIGURE 7-2: Setup for the MCP3424 Evaluation Board with PICkit™ Serial Analyzer. FIGURE 7-3: Example of PICkit™ Serial User Interface. 8.0 Packaging Information 8.1 Package Marking Information
