Datasheet DN2535 (Microchip) - 2
ManufacturerMicrochip
DescriptionN-Channel Depletion-Mode Vertical DMOS FETs Features
Pages / Page6 / 2 — DN2535. Thermal Characteristics. Package. Power Dissipation. I †. …
File Format / SizePDF / 772 Kb
DN2535. Thermal Characteristics. Package. Power Dissipation. I †. (continuous)†. (pulsed). @T = 25OC. DRM. Notes:
DN2535 Thermal Characteristics Package Power Dissipation I † (continuous)† (pulsed) @T = 25OC DRM Notes:
DN2535 Thermal Characteristics Package I I Power Dissipation D D I † I (continuous)† (pulsed) @T = 25OC DR DRM C
TO-92 120mA 500mA 1.0W 120mA 500mA TO-220 500mA 500mA 15W 500mA 500mA
Notes:
† I (continuous) is limited by max rated T. D j
Electrical Characteristics
(T = 25OC unless otherwise specified) A
Sym Parameter Min Typ Max Units Conditions
BV Drain-to-source breakdown voltage 350 - - V V = -5.0V, I = 100µA DSX GS D V Gate-to-source off voltage -1.5 - -3.5 V V = 25V, I = 10µA GS(OFF) DS D ΔV Change in V with temperature - - -4.5 mV/OC V = 25V, I = 10µA GS(OFF) GS(OFF) DS D I Gate body leakage current - - 100 nA V = ±20V, V = 0V GSS GS DS - - 10 µA V = Max rating, V = -10V DS GS I Drain-to-source leakage current D(OFF) - - 1.0 mA V = 0.8 Max Rating, DS V = -10V, T = 125OC GS A I Saturated drain-to-source current 150 - - mA V = 0V, V = 25V DSS GS DS R Static drain-to-source on-state resistance - 17 25 Ω V = 0V, I = 120mA DS(ON) GS D ΔR Change in R with temperature - - 1.1 %/OC V = 0V, I = 120mA DS(ON) DS(ON) GS D G Forward transconductance - 325 - mmho V = 10V, I = 100mA FS DS D C Input capacitance - 200 300 ISS V = -10V, GS C Common source output capacitance - 12 30 pF V = 25V, OSS DS f = 1.0MHz C Reverse transfer capacitance - 1.0 5.0 RSS t Turn-on delay time - - 10 d(ON) V = 25V, t Rise time - - 15 DD r ns I = 150mA, D t Turn-off delay time - - 15 d(OFF) R = 25Ω, GEN t Fall time - - 20 f V Diode forward voltage drop - - 1.8 V V = -10V, I = 120mA SD GS SD t Reverse recovery time - 800 - ns V = -10V, I = 1.0A rr GS SD
Notes:
1. All D.C. parameters 100% tested at 25OC unless otherwise stated. (Pulse test: 300µs pulse, 2% duty cycle.) 2. All A.C. parameters sample tested.
Switching Waveforms and Test Circuit 0V
90%
VDD INPUT Pulse
R 10%
Generator
L
-10V OUTPUT
t t (ON) (OFF) RGEN t t t t d(ON) r d(OFF) f
VDD INPUT
10% 10%
D.U.T. OUTPUT 0V
90% 90% Doc.# DSFP-DN2535
Supertex inc.
B062813 2
www.supertex.com
