Datasheet DN2625 (Microchip) - 4
Manufacturer | Microchip |
Description | N-Channel Depletion-Mode Vertical DMOS FET in Single and Dual Options |
Pages / Page | 14 / 4 — DN2625. 2.0. TYPICAL PERFORMANCE CURVES. Note:. FIGURE 2-1:. FIGURE 2-4:. … |
File Format / Size | PDF / 998 Kb |
DN2625. 2.0. TYPICAL PERFORMANCE CURVES. Note:. FIGURE 2-1:. FIGURE 2-4:. FIGURE 2-2:. FIGURE 2-5:. FIGURE 2-3:. FIGURE 2-6:
DN2625 2.0 TYPICAL PERFORMANCE CURVES Note:
The graphs and tables provided following this note are a statistical summary based on a limited number of samples and are provided for informational purposes only. The performance characteristics listed herein are not tested or guaranteed. In some graphs or tables, the data presented may be outside the specified operating range (e.g. outside specified power supply range) and therefore outside the warranted range. 7.0 1.20 1.15 6.0 VGS = 2.0V 1.10 5.0 VGS = 1.5V V 1.05 GS = 1.0V V 4.0 GS = 0.5V V = -2.5V (amps) GS V 1.00 I = 1mA I D GS = 0V D VGS = -0.5V (normalized) 3.0 V 0.95 GS = -1.0V DSX VGS = -1.5V BV 0.90 2.0 VGS = -2.0V 0.85 1.0 0.80-50 -25 0 25 50 75 100 125 150 0.0 0 50 100 150 200 250 T (OC) j V (volts) DS
FIGURE 2-1:
Output Characteristics.
FIGURE 2-4:
BVDSX Variation with Temperature. 10 -55OC 9 5.0 V = 1V GS 8 4.5 4.0 7 25OC 3.5 6 3.0 125OC 5 2.5 (amps) (ohms) I D 4 2.0 DS(ON) 1.5 3 R 1.0 2 0.5 1 0.00.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0-3.0 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 I (A) D V (V) GS
FIGURE 2-2:
Transfer Characteristics.
FIGURE 2-5:
On-resistance vs. Drain Current. 1.25 2.50 5.5 V = -2V GS 2.25 5.0 1.20 V = -1.5V GS V = -1V 4.5 GS 1.15 2.00 V = -0.5V GS 4.0 V = 0V GS 1.10 1.75 V = 0.5V GS 3.5 V = 1V V @100µA GS 1.05 GS(OFF) 1.50 3.0 V = 1.5V V = 15V (A) GS DS V = 2V I D GS (normalized) 1.00 1.25 (normalized) 2.5 2.0 0.95 1.00 R @V = 1V DS(ON) GS GS(OFF) DS(ON) 1.5 V I =1A R 0.90 D 0.75 1.0 0.85 0.50 0.5 0.80 0.25 0.0 -50 -25 0 25 50 75 100 125 150 0 1 2 3 4 5 6 7 8 9 10 V (V) T (OC) j DS
FIGURE 2-3:
Saturation Characteristics.
FIGURE 2-6:
VGS(OFF) and RDS(ON) Variation with Temperature. DS20005537B-page 4 2017 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics Absolute Maximum Ratings† Temperature Specifications Thermal characteristics 2.0 Typical Performance Curves FIGURE 2-1: Output Characteristics. FIGURE 2-2: Transfer Characteristics. FIGURE 2-3: Saturation Characteristics. FIGURE 2-4: BVDSX Variation with Temperature. FIGURE 2-5: On-resistance vs. Drain Current. FIGURE 2-6: VGS(OFF) and RDS(ON) Variation with Temperature. FIGURE 2-7: Transconductance vs. Drain Current. 3.0 Pin Description TABLE 3-1: TO-252 D-PAK Pin Function Table TABLE 3-2: 8-lead DFN (dual Pad) Pin Function Table 4.0 Functional Description FIGURE 4-1: Switching Waveforms and Test Circuit. Product Summary 5.0 Packaging Information 5.1 Package Marking Information
