Supertex inc.VP0550P-Channel Enhancement-ModeVertical DMOS FETsFeaturesGeneral Description ► Free from secondary breakdown This enhancement-mode (normally-off) transistor utilizes ► Low power drive requirement a vertical DMOS structure and Supertex’s well-proven, ► Ease of paralleling silicon-gate manufacturing process. This combination ► Low C and fast switching speeds produces a device with the power handling capabilities ISS of bipolar transistors and the high input impedance and ► Excellent thermal stability positive temperature coefficient inherent in MOS devices. ► Integral source-drain diode Characteristic of all MOS structures, this device is free ► High input impedance and high gain from thermal runaway and thermally-induced secondary Applications breakdown. ► Motor controls Supertex’s vertical DMOS FETs are ideally suited to a ► Converters wide range of switching and amplifying applications where ► Amplifiers very low threshold voltage, high breakdown voltage, high ► Switches input impedance, low input capacitance, and fast switching ► Power supply circuits speeds are desired. ► Drivers (relays, hammers, solenoids, lamps, memories, displays, bipolar transistors, etc.) Ordering InformationProduct SummaryPart NumberPackage OptionPackingRIBV /BVDS(ON)D(ON)DSSDGS VP0550N3-G TO-92 1000/Bag (max)(min) VP0550N3-G P002 -500V 125Ω -100mA VP0550N3-G P003 VP0550N3-G P005 TO-92 2000/Reel Pin Configuration VP0550N3-G P013 VP0550N3-G P014 -G denotes a lead (Pb)-free / RoHS compliant package. Contact factory for Wafer / Die availablity. Devices in Wafer / Die form are lead (Pb)-free / RoHS compliant. DRAINAbsolute Maximum RatingsSOURCEParameterValueGATE Drain-to-source voltage BVDSS TO-92 Drain-to-gate voltage BVDGS Gate-to-source voltage ±20V Product Marking Operating and storage temperature -55OC to +150OC SiVP YY = Year Sealed Absolute Maximum Ratings are those values beyond which damage to the device may occur. Functional operation under these conditions is not implied. Continuous operation 0 5 5 0 WW = Week Sealed of the device at the absolute rating level may affect device reliability. All voltages are Y Y W W = “Green” Packaging referenced to device ground. Package may or may not include the following marks: Si or Typical Thermal ResistanceTO-92Packageθja TO-92 132OC/W Doc.# DSFP-VP0550 Supertex inc. C082313 www.supertex.com
