Datasheet LTC4300A-1, LTC4300A-2 (Analog Devices) - 4
DescriptionHot Swappable 2-Wire Bus Buffers
Pages / Page16 / 4 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 4:. Note 5:. Note 6:. Note 2:. …
File Format / SizePDF / 186 Kb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 4:. Note 5:. Note 6:. Note 2:. Note 3:. TYPICAL PERFORMANCE CHARACTERISTICS
ELECTRICAL CHARACTERISTICS Note 1: Note 4: Note 5: Note 6: Note 2: Note 3: TYPICAL PERFORMANCE CHARACTERISTICS
LTC4300A-1/LTC4300A-2
Note 4:
Guaranteed by design, not subject to test. may cause permanent damage to the device. Exposure to any Absolute
Note 5:
CB = total capacitance of one bus line in pF. Maximum Rating condition for extended periods may affect device
Note 6:
These tests measure the difference in high-to-low propagation reliability and lifetime. delay tPHL between the clock and data channels. The delay on each
Note 2:
IPULLUPAC varies with temperature and VCC voltage, as shown in channel is measured from the 50% point of the falling driven input signal the Typical Performance Characteristics section. to the 50% point of the output driven by the LTC4300A-1/LTC4300A-2.
Note 3:
The connection circuitry always regulates its output to a higher The skew is defined as (tPHL(SCL) – tPHL(SDA)). Testing is performed in voltage than its input. The magnitude of this offset voltage as a function of both directions—from input bus to output bus and vice versa. Tests are the pull-up resistor and VCC voltage is shown in the Typical Performance performed with approximately 500pF of distributed equivalent capacitance Characteristics section. on each SDA and SCL pin.
TYPICAL PERFORMANCE CHARACTERISTICS Input – Output tPHL vs ICC vs Temperature (LTC4300A-1) Temperature (LTC4300A-1)
5.3 100 V 5.2 CC = 2.7V VCC = 5.5V 5.1 80 5.0 VCC = 3.3V 4.9 60 (mA) 4.8 (ns) I CC 4.7 t PHL 40 VCC = 2.7V VCC = 5.5V 4.6 4.5 20 CIN = COUT = 100pF 4.4 RPULLUPIN = RPULLUPOUT = 10k 4.3 0 –40 25 85 –50 –25 0 25 50 75 100 TEMPERATURE (°C) TEMPERATURE (°C) 4300a12 G01 4300a12 G02
IPULLUPAC vs Temperature Connection Circuitry VOUT – VIN
12 300 TA = 25°C VIN = 0V 10 VCC = 5V 250 8 200 (mA) (mV) IN 6 150 – V VCC = 5V I PULLUPAC V OUT 4 CC = 3V V 100 VCC = 3.3V 2 50 VCC = 2.7V 0 0 –50 –25 0 25 50 75 100 0 10,000 20,000 30,000 40,000 TEMPERATURE (°C) RPULLUP (Ω) 4300a12 G03 4300a12 G04 4300a12fa 4
