Datasheet LTC4301 (Analog Devices) - 2
DescriptionSupply Independent Hot Swappable 2-Wire Bus Buffer
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. Order …
File Format / SizePDF / 229 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. Order Options. ELECTRICAL CHARACTERISTICS The
ABSOLUTE MAXIMUM RATINGS (Note 1) PACKAGE/ORDER INFORMATION Order Options ELECTRICAL CHARACTERISTICS The
LTC4301
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
VCC to GND ... –0.3V to 7V Storage Temperature Range SDAIN, SCLIN, SDAOUT, SCLOUT, CS .. –0.3V to 7V MSOP ... – 65°C to 150°C READY .. –0.3V to 6V DFN .. – 65°C to 125°C Operating Temperature Range Lead Temperature (Soldering, 10 sec).. 300°C LTC4301C ... 0°C to 70°C LTC4301I .. – 40°C to 85°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW ORDER PART ORDER PART NUMBER NUMBER CS 1 8 VCC TOP VIEW LTC4301CDD LTC4301CMS8 SCLOUT 2 7 SDAOUT CS 1 8 VCC 9 SCLIN 3 6 SDAIN LTC4301IDD SCLOUT 2 7 SDAOUT LTC4301IMS8 SCLIN 3 6 SDAIN GND 4 5 READY GND 4 5 READY DD PART MS8 PART MARKING* MS8 PACKAGE DD PACKAGE 8-LEAD PLASTIC MSOP MARKING* 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 125°C, θJA = 200°C/W T LBBY LTBBW JMAX = 125°C, θJA = 43°C/W EXPOSED PAD (PIN 9) PCB CONNECTION OPTIONAL
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges.
indicates specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = 2.7V to 5.5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Power Supply
VCC Positive Supply Voltage ● 2.7 5.5 V ICC Supply Current VCC = 5.5V, VSDAIN = VSCLIN = 0V ● 4.5 6.2 mA VCC = 5.5V, CS = 5.5V 300 µA
Start-Up Circuitry
VPRE Precharge Voltage SDA, SCL Floating ● 0.85 1.05 1.25 V tIDLE Bus Idle Time ● 60 95 175 µs RDYVOL READY Output Low Voltage IPULLUP = 3mA ● 0.4 V VTHRCS Connection Sense Threshold 0.8 1.4 2 V ICS CS Input Current CS from 0V to VCC ±0.1 ±1 µA VTHR SDA, SCL Logic Input Threshold Voltage Rising Edge 1.55 1.8 2.0 V VHYS SDA, SCL Logic Input Threshold Voltage (Note 3) 50 mV Hysteresis tPLH CS Delay On-Off 10 ns READY Delay Off-On 10 ns tPHL CS Delay Off-On 95 µs READY Delay On-Off 10 ns IOFF Ready Off Leakage Current ±0.1 µA 4301fb 2
