Datasheet LTC4312 (Analog Devices) - 3
DescriptionPin-Selectable, 2-Channel, 2-Wire Multiplexer with Bus Buffers
Pages / Page20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 200 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC4312
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCC = VCC2 = 3.3V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Power Supply/Start-Up
VCC Input Supply Range l 2.9 5.5 V VDD, BUS 2-Wire Bus Supply Voltage l 2.25 5.5 V VCC2 Output Side Accelerator Supply l 2.25 5.5 V Range ICC Input Supply Current One or Both VENABLE1-2 = VCC = VCC2 = 5.5V (Note 3) l 6.0 7.3 9 mA ICC(DISABLED) Input Supply Current VENABLE1-2 = 0V; VCC = VCC2 = 5.5V (Note 3) l 1.6 2.2 3.5 mA ICC2 VCC2 Supply Current One or Both VENABLE1-2 = VCC = VCC2 = 5.5V (Note 3) l 0.35 0.5 0.6 mA tUVLO UVLO Delay l 60 110 200 μs VTH_UVLO UVLO Threshold l 2.3 2.6 V VCC_UVLO(HYST) UVLO Threshold Hysteresis 200 mV Voltage
Buffers
VOS1(SAT) Buffer Offset Voltage IOL = 4mA, Driven VSDAIN,SCLIN = 50mV l 130 220 280 mV IOL = 500μA, Driven VSDAIN,SCLIN = 50mV l 15 60 120 mV VOS2(SAT) Buffer Offset Voltage IOL = 4mA, Driven VSDAOUT,SCLOUT = 50mV l 90 190 260 mV IOL = 500μA, Driven VSDAOUT,SCLOUT = 50mV l 15 55 110 mV VOS Buffer Offset Voltage IOL = 4mA, Driven VSDAIN,SCLIN = 200mV l 50 130 195 mV IOL = 500μA, Driven VSDAIN,SCLIN = 200mV l 15 55 110 mV VOS2 Buffer Offset Voltage IOL = 4mA, Driven VSDAOUT,SCLOUT = 200mV l 35 95 170 mV IOL = 500μA, Driven VSDAOUT,SCLOUT = 200mV l 15 50 100 mV VIL,FALLING Buffer Input Logic Low Voltage SDA, SCL Pins (Notes 4, 5) l 0.3•VMIN 0.33•VMIN 0.36•VMIN V VIL,RISING Buffer Input Logic Low Voltage SDA, SCL Pins; ACC Grounded l 0.5 0.6 0.7 V SDA, SCL Pins; ACC Open or High (Notes 4, 5) l 0.3•VMIN 0.33•VMIN 0.36•VMIN V ILEAK Input Leakage Current SDA, SCL Pins; VCC, VCC2 = 0V, 5.5V l ±10 μA CIN Input Capacitance SDA, SCL Pins (Note 6) <20 pF
Rise Time Accelerators
dV/dt (RTA) Minimum Slew Rate Requirement SDA, SCL Pins; VCC = VCC2 = 5V l 0.1 0.2 0.4 V/μs VRTA(TH) Rise Time Accelerator DC SDA, SCL Pins; VCC = VCC2 = 5V, ACC Grounded l 0.7 0.8 0.9 V Threshold Voltage ACC Open or High, VCC = VCC2 = 5V (Note 4) l 0.36•VMIN 0.4•VMIN 0.44•VMIN V ΔVACC Buffers Off to Accelerator On SDA, SCL Pins; VCC = VCC2 = 5V, ACC Grounded l 100 200 mV Voltage ACC Open, VCC = VCC2 = 5V (Note 4) l 0.05•VMIN 0.07•VMIN mV IRTA Rise Time Accelerator Pull-Up SDA, SCL Pins; VCC = VCC2 = 5V, ACC Grounded l 20 35 45 mA Current (Note 7) ACC Open, VCC = VCC2 = 5V (Note 7) l 1.5 3 4 mA
Enable/Control
VDISCEN(TH) DISCEN Threshold Voltage l 0.8 1.4 2 V ΔVDISCEN(HYST) DISCEN Hysteresis Voltage 20 mV VEN(TH) ENABLE1-2 Threshold Voltage l 0.8 1.4 2 V ΔVEN(HYST) ENABLE1-2 Hysteresis Voltage 20 mV tLH_EN ENABLE1-2 High to Buffer Active 0.56 1 μs 4312f 3
