Datasheet LTC5508 (Analog Devices) - 8
Description300MHz to 7GHz RF Power Detector with Buffered Output in SC70 Package
Pages / Page8 / 8 — PACKAGE DESCRIPTIO. SC6 Package. 6-Lead Plastic SC70. RELATED PARTS. PART …
File Format / SizePDF / 264 Kb
PACKAGE DESCRIPTIO. SC6 Package. 6-Lead Plastic SC70. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS. RF Power Controllers
PACKAGE DESCRIPTIO SC6 Package 6-Lead Plastic SC70 RELATED PARTS PART NUMBER DESCRIPTION COMMENTS RF Power Controllers
LTC5508
U PACKAGE DESCRIPTIO SC6 Package 6-Lead Plastic SC70
(Reference LTC DWG # 05-08-1638) 0.47 0.65 1.80 – 2.20 MAX REF (NOTE 4) 1.16 REF INDEX AREA (NOTE 6) 1.15 – 1.35 1.80 – 2.40 3.26 MAX 2.1 REF 0.96 MIN (NOTE 4) PIN 1 RECOMMENDED SOLDER PAD LAYOUT 0.15 – 0.30 0.65 BSC PER IPC CALCULATOR 6 PLCS (NOTE 3) 0.10 – 0.40 0.80 – 1.00 0.00 – 0.10 NOTE: REF 1. DIMENSIONS ARE IN MILLIMETERS 1.00 MAX 2. DRAWING NOT TO SCALE 3. DIMENSIONS ARE INCLUSIVE OF PLATING 4. DIMENSIONS ARE EXCLUSIVE OF MOLD FLASH AND METAL BURR 5. MOLD FLASH SHALL NOT EXCEED 0.254mm 6. DETAILS OF THE PIN 1 INDENTIFIER ARE OPTIONAL, 0.10 – 0.30 BUT MUST BE LOCATED WITHIN THE INDEX AREA 0.10 – 0.18 SC6 SC70 0802 7. EIAJ PACKAGE REFERENCE IS EIAJ SC-70 (NOTE 3)
LTC1757A RF Power Controller Single/Dual Band GSM/DCS/GPRS Mobile Phones LTC1758 RF Power Controller Single/Dual Band GSM/DCS/GPRS Mobile Phones LTC1957 RF Power Controller Single/Dual Band GSM/DCS/GPRS Mobile Phones LTC4400 SOT-23 RF PA Controller Single/Dual Band GSM/DCS/GPRS Phones, 45dB Dynamic Range, 450kHz Loop BW LTC4401 SOT-23 RF PA Controller Single/Dual Band GSM/DCS/GPRS Phones, 45dB Dynamic Range, 250kHz Loop BW LT5500 1.8GHz to 2.7GHz RF Front End Dual LNA gain Setting +13.5dB/–14dB at 2.5GHz, Double-Balanced Mixer, 1.8V ≤ VSUPPLY ≤ 5.25V LT5502 400MHz Quadrature Demodulator with RSSI 1.8V to 5.25V Supply, 70MHz to 400MHz IF, 84dB Limiting Gain, 90dB RSSI Range LT5503 1.2GHz to 2.7GHz Direct IQ Modulator and 1.8V to 5.25V Supply, Four-Step RF Power Control, 120MHz Modulation Bandwidth Up Converting Mixer LT5504 800MHz to 2.7GHz RF Measuring Receiver 80dB Dynamic Range, Temperature Compensated, 2.7V to 5.5V Supply LTC5505 300MHz to 3.5GHz RF Power Detector >40dB Dynamic Range, Temperature Compensated, 2.7V to 6V Supply LT5506 500MHz Quadrature IF Demodulator with VGA 1.8V to 5.25V Supply, 40MHz to 500MHz IF, –4dB to 57dB Linear Power Gain LTC5507 100kHz to 1GHz RF Power Detector 48dB Dynamic Range, Temperature Compensated, 2.7V to 6V Supply LT5511 High Signal Level Up Converting Mixer RF Output to 3GHz, 17dBm IIP3, Integrated LO Buffer LT5512 High Signal Level Down Converting Mixer DC-3GHz, 20dBm IIP3, Integrated LO Buffer 5508fa LT/TP REV A 0603 1K • PRINTED IN USA 8 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2002
