Datasheet LTC5532 (Analog Devices) - 4
DescriptionPrecision 300MHz to 7GHz RF Detector with Gain and Offset Adjustment
Pages / Page16 / 4 — TYPICAL PERFOR A CE CHARACTERISTICS (RLOAD = 20k) Characteristics are for …
File Format / SizePDF / 289 Kb
TYPICAL PERFOR A CE CHARACTERISTICS (RLOAD = 20k) Characteristics are for both packages. unless otherwise indicated
TYPICAL PERFOR A CE CHARACTERISTICS (RLOAD = 20k) Characteristics are for both packages unless otherwise indicated
LTC5532
W U TYPICAL PERFOR A CE CHARACTERISTICS (RLOAD = 20k) Characteristics are for both packages unless otherwise indicated. Typical Detector Characteristics, Typical Detector Characteristics, 6000MHz, Gain = 2, VOS = 0V 7000MHz, Gain = 2, V Typical Detector Characteristics, OS = 0V (SOT-23 Package) (SOT-23 Package) 300MHz, Gain = 4, VOS = 0V
3600 3600 3600 VCC = 3.6V VCC = 3.6V VCC = 3.6V 3200 3200 3200 TA = –40°C 2800 2800 2800 TA = –40°C 2400 2400 2400 TA = –40°C 2000 2000 2000 TA = 25°C T 1600 1600 A = 25°C T 1600 A = 25°C 1200 1200 1200 OUTPUT VOLTAGE (mV) OUTPUT VOLTAGE (mV) OUTPUT VOLTAGE (mV) TA = 85°C OUT 800 OUT 800 OUT 800 V V V TA = 85°C 400 400 400 TA = 85°C 0 0 0 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 –32 –27 –22 –17 –12 –7 –2 3 8 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 RF INPUT POWER (dBm) RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5532 G07 5532 G11 5532 G12
Typical Detector Characteristics, VOUT vs RF Input Power and VOS, 1000MHz, Gain = 4, VOS = 0V 300MHz, Gain = 2
3600 3600 VCC = 3.6V VCC = 3.6V 3200 3200 TA = 25°C TA = –40°C 2800 2800 2400 2400 2000 2000 TA = 25°C 1600 1600 1200 1200 OUTPUT VOLTAGE (mV) OUTPUT VOLTAGE (mV) VOS = 1V OUT 800 OUT 800 V V T V A = 85°C OS = 0.5V 400 400 VOS = 0.2V VOS = 0V 0 0 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5532 G13 5532 G14
VOUT vs RF Input Power, 300MHz VOUT vs RF Input Power and VOS, and 1000MHz, Gain = 2 and 4, 1000MHz, Gain = 2 VOS = 0V
3600 3600 VCC = 3.6V VCC = 3.6V 300MHz 3200 TA = 25°C 3200 TA = 25°C GAIN = 4 2800 2800 1000MHz GAIN = 4 2400 2400 2000 2000 1600 1600 1200 1200 OUTPUT VOLTAGE (mV) VOS = 1V OUTPUT VOLTAGE (mV) OUT 800 OUT 800 300MHz V V V OS = 0.5V GAIN = 2 400 V 400 OS = 0.2V 1000MHz VOS = 0V GAIN = 2 0 0 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5532 G15 5532 G16 5532f 4
