Datasheet LTC5533 (Analog Devices) - 3
Description | 300MHz to 11GHz Precision Dual RF Power Detector |
Pages / Page | 12 / 3 — TYPICAL PERFOR A CE CHARACTERISTICS (For one channel. SHDN = VCC, unless. … |
File Format / Size | PDF / 252 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS (For one channel. SHDN = VCC, unless. otherwise specified.)
LTC5533
W U TYPICAL PERFOR A CE CHARACTERISTICS (For one channel. SHDN = VCC, unless otherwise specified.) Output Starting Voltage vs Supply Shutdown Current vs Supply Voltage (RF Input Signal Off, Supply Current vs Supply Voltage Voltage (RF Input Signal Off, VOS = 0V) (RF Input Signal Off, VOS = 0V) VOS = 0V, SHDN = 0V)
140 500 3.0 2.5 TA = 85°C 135 A) 480 TA = 85°C µ TA = –40°C 2.0 T 130 A = 25°C 460 1.5 TA = 25°C T OUTPUT VOLTAGE (mV) A = –40°C 1.0 125 SUPPLY CURRENT ( 440 TA = 85°C OUT SHUTDOWN CURRENT (nA) V 0.5 TA = 25°C TA = –40°C 120 420 0 2.5 3 3.5 4 4.5 5 5.5 6 2.5 3 3.5 4 4.5 5 5.5 6 2.5 3 3.5 4 4.5 5 5.5 6 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) 5533 G01 5533 G02 5533 G03
Typical Detector Characteristics, Typical Detector Characteristics, Typical Detector Characteristics, 300MHz 1GHz 2GHz
3600 3600 3600 VCC = 3.6V VCC = 3.6V VCC = 3.6V 3200 VOS = 0V 3200 VOS = 0V 3200 VOS = 0V 2800 2800 2800 TA = –40°C TA = –40°C TA = –40°C 2400 2400 2400 TA = 25°C TA = 25°C 2000 2000 2000 TA = 25°C 1600 1600 1600 1200 OUTPUT VOLTAGE (mV) 1200 1200 T OUTPUT VOLTAGE (mV) OUTPUT VOLTAGE (mV) A = 85°C TA = 85°C TA = 85°C OUT 800 V OUT 800 OUT 800 V V 400 400 400 0 0 0 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 RF INPUT POWER (dBm) RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5533 G04 5533 G05 5533 G06
Typical Detector Characteristics, Typical Detector Characteristics, Typical Detector Characteristics, 3GHz 5GHz 7GHz
3600 3600 3600 VCC = 3.6V VCC = 3.6V VCC = 3.6V 3200 VOS = 0V 3200 VOS = 0V 3200 VOS = 0V 2800 2800 2800 TA = –40°C 2400 2400 2400 TA = 25°C TA = –40°C TA = –40°C 2000 2000 2000 TA = 25°C 1600 1600 1600 TA = 25°C 1200 1200 OUTPUT VOLTAGE (mV) OUTPUT VOLTAGE (mV) 1200 T OUTPUT VOLTAGE (mV) A = 85°C OUT 800 OUT 800 V V OUT 800 T V A = 85°C TA = 85°C 400 400 400 0 0 0 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 –32 –28 –24 –20 –16 –12 –8 –4 0 4 8 12 RF INPUT POWER (dBm) RF INPUT POWER (dBm) RF INPUT POWER (dBm) 5533 G07 5533 G08 5533 G09 5533f 3
