Datasheet ADXL372 (Analog Devices) - 5
DescriptionMicropower, 3-Axis, ±200 g Digital Output, MEMS
Pages / Page57 / 5 — ADXL372. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Test …
File Format / SizePDF / 980 Kb
ADXL372. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADXL372 Data Sheet SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
TA = 25°C, VS = 2.5 V, VDDI/O = 2.5 V, 3200 Hz ODR, 1600 Hz bandwidth, acceleration = 0 g, default register settings, unless otherwise noted. Al minimum and maximum specifications are guaranteed. Typical specifications may not be guaranteed.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
SENSOR INPUT Each axis Measurement Range ±200 g Nonlinearity Percentage of full scale ±0.5 % Sensor Resonant Frequency 16 kHz Cross Axis Sensitivity1 ±2.5 % OUTPUT RESOLUTION Each axis All Operating Modes 12 Bits SCALE FACTOR Each axis Scale Factor Calibration Error ±10 % Scale Factor at XOUT, YOUT, ZOUT Expressed in mg/LSB 100 mg/LSB Expressed in LSB/g 10 LSB/g Scale Factor Change Due to Temperature2 0.1 %/°C 0 g OFFSET Each axis 0 g Output XOUT, YOUT, ZOUT At VS = 2.5 V −3 ±1 +3 g 1.6 V ≤ VS ≤ 3.5 V −7 ±1 +7 g 0 g Offset vs. Temperature2 Normal Operation XOUT, YOUT, ZOUT ±50 mg/°C Low Noise Mode XOUT, YOUT, ZOUT ±35 mg/°C NOISE PERFORMANCE RMS Noise Each axis Normal Operation 3.5 LSB Low Noise Mode 3 LSB BANDWIDTH User selectable ODR 400 6400 Hz High-Pass Filter, −3 dB Corner3 0.24 30.48 Hz Low-Pass (Antialiasing) Filter, −3 dB Corner4 4-pole low-pass filter 200 ODR/2 Hz POWER SUPPLY Operating Voltage Range (VS) 1.6 2.5 3.5 V Input/Output Voltage Range (VDDI/O) 1.6 2.5 VS V Supply Current Measurement Mode 3200 Hz ODR Normal Operation 22 µA Low Noise Mode 33 µA Instant On Mode 1.4 µA Wake-Up Mode Varies with wake-up rate At slowest wake-up rate 0.77 µA Standby <0.1 µA Power Supply Rejection Ratio (PSRR) CS = 1.1 µF, CIO = 1.1 µF, input is 100 mV sine wave on VS Input Frequency 100 Hz to 1 kHz −20 dB 1 kHz to 250 kHz −17 dB Rev. 0 | Page 4 of 56 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measurement Mode Instant On Mode Wake-Up Mode Standby BANDWIDTH Low-Pass Antialiasing Filter High-Pass Filter Filter Settling Time Selectable ODR POWER/NOISE TRADE-OFF POWER SAVINGS AUTONOMOUS EVENT DETECTION ACTIVITY AND INACTIVITY Low-Pass Activity Detect Filter Activity Detection Referenced and Absolute Configurations Activity Timer Activity Detection in Wake-Up Mode Inactivity Detection Referenced and Absolute Configurations Inactivity Timer Linking Activity and Inactivity Detection Default Mode Linked Mode Loop Mode Autosleep Using the AWAKE Bit MOTION WARNING IMPACT DETECTION FEATURES WIDE BANDWIDTH INSTANT ON IMPACT DETECTION CAPTURING IMPACT EVENTS FIFO BENEFITS OF THE FIFO System Level Power Savings Data Recording/Event Context USING THE FIFO FIFO Disabled Oldest Saved Mode (First N) Stream Mode (Last N) Triggered Mode RETRIEVING DATA FROM FIFO INTERRUPTS INTERRUPT PINS Alternate Functions TYPES OF INTERRUPTS Activity and Inactivity Interrupts Data Ready Interrupt FIFO Interrupts FIFO Watermark FIFO Ready Overrun ADDITIONAL FEATURES USING AN EXTERNAL CLOCK SYNCHRONIZED DATA SAMPLING SELF TEST Self Test Procedure USER REGISTER PROTECTION USER OFFSET TRIMS SERIAL COMMUNICATIONS SERIAL INTERFACE SPI Protocol I2C Protocol MULTIBYTE TRANSFERS INVALID ADDRESSES AND ADDRESS FOLDING SPI Timing Diagrams I2C Timing Diagrams REGISTER MAP REGISTER DETAILS ANALOG DEVICES ID REGISTER ANALOG DEVICES MEMS ID REGISTER DEVICE ID REGISTER PRODUCT REVISION ID REGISTER STATUS REGISTER ACTIVITY STATUS REGISTER FIFO ENTRIES REGISTER, MSB FIFO ENTRIES REGISTER, LSB X-AXIS DATA REGISTER, MSB X-AXIS DATA REGISTER, LSB Y-AXIS DATA REGISTER, MSB Y-AXIS DATA REGISTER, LSB Z-AXIS DATA REGISTER, MSB Z-AXIS DATA REGISTER, LSB HIGHEST PEAK DATA REGISTERS X-AXIS HIGHEST PEAK DATA REGISTER, MSB X-AXIS HIGHEST PEAK DATA REGISTER, LSB Y-AXIS HIGHEST PEAK DATA REGISTER, MSB Y-AXIS HIGHEST PEAK DATA REGISTER, LSB Z-AXIS HIGHEST PEAK DATA REGISTER, MSB Z-AXIS HIGHEST PEAK DATA REGISTER, LSB OFFSET TRIM REGISTERS X-AXIS OFFSET TRIM REGISTER, LSB Y-AXIS OFFSET TRIM REGISTER, LSB Z-AXIS OFFSET TRIM REGISTER, LSB X-AXIS ACTIVITY THRESHOLD REGISTER, MSB X-AXIS OF ACTIVITY THRESHOLD REGISTER, LSB Y-AXIS ACTIVITY THRESHOLD REGISTER, MSB Y-AXIS OF ACTIVITY THRESHOLD REGISTER, LSB Z-AXIS ACTIVITY THRESHOLD REGISTER, MSB Z-AXIS OF ACTIVITY THRESHOLD REGISTER, LSB ACTIVITY TIME REGISTER X-AXIS INACTIVITY THRESHOLD REGISTER, MSB X-AXIS OF INACTIVITY THRESHOLD REGISTER, LSB Y-AXIS INACTIVITY THRESHOLD REGISTER, MSB Y-AXIS OF INACTIVITY THRESHOLD REGISTER, LSB Z-AXIS INACTIVITY THRESHOLD REGISTER, MSB Z-AXIS OF INACTIVITY THRESHOLD REGISTER, LSB INACTIVITY TIME REGISTERS INACTIVITY TIMER REGISTER, MSB INACTIVITY TIMER REGISTER, LSB X-AXIS MOTION WARNING THRESHOLD REGISTER, MSB X-AXIS OF MOTION WARNING NOTIFICATION REGISTER, LSB Y-AXIS MOTION WARNING NOTIFICATION THRESHOLD REGISTER, MSB Y-AXIS OF MOTION WARNING NOTIFICATION REGISTER, LSB Z-AXIS MOTION WARNING NOTIFICATION THRESHOLD REGISTER, MSB Z-AXIS MOTION WARNING NOTIFICATION REGISTER, LSB HIGH-PASS FILTER SETTINGS REGISTER FIFO SAMPLES REGISTER FIFO CONTROL REGISTER INTERRUPT PIN FUNCTION MAP REGISTERS INT2 FUNCTION MAP REGISTER EXTERNAL TIMING CONTROL REGISTER MEASUREMENT CONTROL REGISTER POWER CONTROL REGISTER SELF TEST REGISTER RESET (CLEARS) REGISTER, PART IN STANDBY MODE FIFO ACCESS REGISTER APPLICATIONS INFORMATION APPLICATION EXAMPLES Power Supply Decoupling Using External Timing Triggers OPERATION AT VOLTAGES OTHER THAN 2.5 V OPERATION AT TEMPERATURES OTHER THAN AMBIENT MECHANICAL CONSIDERATIONS FOR MOUNTING AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
