Datasheet ADXL288 (Analog Devices)
DescriptionHigh Performance, Dual-Axis Digital Output Accelerometer
Pages / Page3 / 1 — High Performance, Dual-Axis. Digital Output Accelerometer. Data Sheet. …
RevisionSp0
File Format / SizePDF / 106 Kb
High Performance, Dual-Axis. Digital Output Accelerometer. Data Sheet. ADXL288. FEATURES. GENERAL DESCRIPTION. ±120 g
Datasheet ADXL288 Analog Devices, Revision: Sp0
High Performance, Dual-Axis Digital Output Accelerometer Data Sheet ADXL288 FEATURES GENERAL DESCRIPTION ±120 g full-scale range
The ADXL288 is a dual-axis accelerometer with signal-
12-bit resolution at 62.5 mg /LSB
conditioned outputs available via a 16-bit SPI interface. Identical,
512 kHz data interpolation rate
independent X and Y sense structures are implemented to create
Sensor frequency response down to dc
a high performance, high integrity acceleration sensing system.
On-demand electromechanical self-test
The X and Y acceleration channels have a nominal ful -scale
Fully differential circuitry for high resistance to EMI/RFI
range of ±120 g and a bandwidth of 408 Hz. The acceleration
Independent x- and y-axis sense structures for robust
data is provided as a 12-bit, twos complement word with a
FMEA performance
resolution of 62.5 mg/LSB.
Independent x- and y-axis arming thresholds Low noise: 1 LSB rms typical
The ADXL288 is available in a 16-lead, narrow-body SOIC
Qualified for automotive applications
package with an exposed pad. The ADXL288 can operate
Temperature range: −40°C to +105°C
at 3.3 V and 5 V and is specified for operation from −40°C
3.3 V and 5 V operation
to +105°C.
APPLICATIONS Impact sensing Shock detection FUNCTIONAL BLOCK DIAGRAM Y SELF- ARM_X IN IT TEST STATE MACHINE P L ARM_Y G NA IN IO M T AR UNC F UX INTERPOLATION Σ-Δ OFFSET/ M AT 512kHz AC SINC3 + FIR FILTER OFFSET DEMOD SENSITIVITY MOD –3dB AT 408Hz CANCELLATION AMP CALIBRATION Y MISO R O E M E AC F MOSI X-AXIS /M R SENSOR S E SENSOR T DRIVERS R E N T I I S SCLK GI SP E R CS UX INTERPOLATION Σ-Δ OFFSET/ M AT 512kHz AC SINC3 + FIR FILTER OFFSET DEMOD SENSITIVITY MOD AMP –3dB AT 408Hz CANCELLATION CALIBRATION R E DEVICE ID O G VDD AT OTP A Y-AXIS TRIM SENSOR LT UL VREG MEMORY SENSOR O G DRIVERS CONFIGURATION V E TIMING R GND GENERATOR EPAD
001 1204- 1 Figure 1. For more information about the ADXL288, please contact the Analog Devices, Inc., Customer Interaction Center at http://www.analog.com/en/content/technical_support_page/fca.html to connect with a technical support specialist.
Rev. Sp0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices f or its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013 Analog Devices, Inc. A ll rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram
