Datasheet ADXL362 (Analog Devices) - 2
DescriptionMicropower, 3-Axis, ±2 g/±4 g/±8 g Digital Output MEMS Accelerometer
Pages / Page45 / 2 — ADXL362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/02/2017. …
RevisionF
ADXL362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/02/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press
ADXL362* PRODUCT PAGE QUICK LINKS Last Content Update: 09/02/2017 COMPARABLE PARTS REFERENCE MATERIALS Press
View a parametric search of comparable parts.
Press
• Analog Devices Introduces Industry’s Lowest Power
EVALUATION KITS
MEMS Accelerometer • ADuCM3029 Cog Development Platform for Ultra Low • Analog Devices MEMS Technology Enables Withings Pulse Power Applications Activity Tracker • ADuCM4050 variant of Cog Development Platform for • Analog Devices’ Ultralow Power Accelerometer Enables Analog Devices Ultra Low Power Technology across MCU Remote IoT Edge Nodes to Monitor Asset Health and RF Transceiver Portfolio • Ultra Low Power MCU Enables 10 Times System-Level • ADXL362 Breakout Board Power Savings and Floating-Point Operation in IoT Applications • ADXL362 Datalogger / Development Board
Solutions Bulletins & Brochures
• Real Time Eval System for Digital Output Sensor • Technologies and Applications for the Internet of Things • Ultra-Low Power Accelerometer with Display Arduino Shield
Technical Articles
• Wireless Sensor Network (WSN) Development Kits for • Blackbox Biometrics testing ADI MEMS for Blast Gauge Your IoT Solutions Monitor • Home is Where the Heart Is
DOCUMENTATION
• Intelligence at the Edge Part 1: The Edge Node
Data Sheet
• Intelligence at the Edge Part 2: Reduced Time to Insight • ADXL362: Micropower Three-Axis, ±2g/±4g/±8g Digital- • Precision Counts in IoT Output MEMS Accelerometer Data Sheet • Soldier-worn sensor that measures the destructive power
User Guides
of explosives uses MEMS accelerometer from Analog • UG-351: Ultralow Power, ±2 g/±4 g/±8 g Digital Devices Accelerometer Breakout Board
DESIGN RESOURCES SOFTWARE AND SYSTEMS REQUIREMENTS
• ADXL362 Material Declaration • ADXL362 - No-OS Driver for Microchip Microcontroller • PCN-PDN Information Platforms • Quality And Reliability • ADXL362 - No-OS Driver for Renesas Microcontroller • Symbols and Footprints Platforms • ADXL362 Input 3-Axis Digital Accelerometer Linux Driver
DISCUSSIONS
• ADXL362 Sample C code and Header Files View all ADXL362 EngineerZone Discussions. • ADXL362 Pmod Xilinx FPGA Reference Design
SAMPLE AND BUY REFERENCE DESIGNS
Visit the product page to see pricing options. • CN0274
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE PACKAGE INFORMATION RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measurement Mode Wake-Up Mode Standby SELECTABLE MEASUREMENT RANGES SELECTABLE OUTPUT DATA RATES Antialiasing POWER/NOISE TRADEOFF POWER SAVINGS FEATURES ULTRALOW POWER CONSUMPTION IN ALL MODES MOTION DETECTION Activity Detection Referenced and Absolute Configurations Fewer False Positives Inactivity Detection Linking Activity and Inactivity Detection Default Mode Linked Mode Loop Mode Autosleep Using the AWAKE Bit FIFO System Level Power Savings Data Recording/Event Context COMMUNICATIONS SPI Instructions Bus Keepers MSB Registers ADDITIONAL FEATURES FREE FALL DETECTION EXTERNAL CLOCK SYNCHRONIZED DATA SAMPLING SELF TEST USER REGISTER PROTECTION TEMPERATURE SENSOR SERIAL COMMUNICATIONS SPI COMMANDS Read and Write Register Commands Read FIFO Command MULTIBYTE TRANSFERS Register Read/Write Auto-Increment INVALID ADDRESSES AND ADDRESS FOLDING LATENCY RESTRICTIONS INVALID COMMANDS REGISTER MAP REGISTER DETAILS DEVICE ID REGISTER DEVICE ID: 0x1D REGISTER PART ID: 0xF2 REGISTER SILICON REVISION ID REGISTER X-AXIS DATA (8 MSB) REGISTER Y-AXIS DATA (8 MSB) REGISTER Z-AXIS DATA (8 MSB) REGISTER STATUS REGISTER FIFO ENTRIES REGISTERS X-AXIS DATA REGISTERS Y-AXIS DATA REGISTERS Z-AXIS DATA REGISTERS TEMPERATURE DATA REGISTERS SOFT RESET REGISTER ACTIVITY THRESHOLD REGISTERS ACTIVITY TIME REGISTER INACTIVITY THRESHOLD REGISTERS INACTIVITY TIME REGISTERS ACTIVITY/INACTIVITY CONTROL REGISTER FIFO CONTROL REGISTER FIFO SAMPLES REGISTER INT1/INT2 FUNCTION MAP REGISTERS FILTER CONTROL REGISTER POWER CONTROL REGISTER SELF TEST REGISTER APPLICATIONS INFORMATION APPLICATION EXAMPLES Device Configuration Autonomous Motion Switch Start-up Routine Using External Timing Triggers Example: Implementing Free Fall Detection Start-up Routine POWER Power Supply Decoupling Power Supply Requirements FIFO MODES FIFO Disabled Oldest Saved Mode Stream Mode Triggered Mode FIFO Configuration FIFO Interrupts Retrieving Data from FIFO INTERRUPTS Interrupt Pins Alternate Functions of Interrupt Pins Activity and Inactivity Interrupts Data Ready Interrupt Using FIFO Interrupts FIFO Watermark FIFO Ready Overrun USING SYNCHRONIZED DATA SAMPLING USING AN EXTERNAL CLOCK USING SELF TEST OPERATION AT VOLTAGES OTHER THAN 2.0 V MECHANICAL CONSIDERATIONS FOR MOUNTING AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
