Datasheet ADXL344 (Analog Devices)
Description | 3-Axis, ±2 g/±4 g/±8 g/±16 g Ultralow Power Digital Accelerometer |
Pages / Page | 41 / 1 — 3-Axis, ±2 g. /±4 g. /±8 g. /±16 g. Ultralow. Power Digital MEMS … |
File Format / Size | PDF / 647 Kb |
3-Axis, ±2 g. /±4 g. /±8 g. /±16 g. Ultralow. Power Digital MEMS Accelerometer. Data Sheet. ADXL344. FEATURES. GENERAL DESCRIPTION
3-Axis, ±2 g /±4 g /±8 g /±16 g Ultralow Power Digital MEMS Accelerometer Data Sheet ADXL344 FEATURES GENERAL DESCRIPTION Multipurpose accelerometer with 10- to 13-bit resolution for
The ADXL344 is a versatile 3-axis, digital-output, low g MEMS
use in a wide variety of applications
accelerometer. Selectable measurement range and bandwidth and
Digital output accessible via SPI (3- and 4-wire) and I2C
configurable, built-in motion detection make it suitable for sensing
Built-in motion detection features make tap, double-tap,
acceleration in a wide variety of applications. Robustness to
activity, inactivity, orientation, and free-fall detection
10,000 g of shock and a wide temperature range (−40°C to +85°C)
trivial
enable use of the accelerometer even in harsh environments.
User-adjustable thresholds
The ADXL344 measures acceleration with high resolution (13-bit)
Interrupts independently mappable to two interrupt pins
measurement at up to ±16 g. Digital output data is formatted as
Low power operation down to 23 µA and embedded FIFO for
16-bit twos complement and is accessible through either a SPI
reducing overall system power
(3- or 4-wire) or I2C digital interface. The ADXL344 can
Wide supply and I/O voltage range: 1.7 V to 2.75 V
measure the static acceleration of gravity in tilt-sensing appli-
Wide operating temperature range (−40°C to +85°C)
cations, as well as dynamic acceleration resulting from motion
10,000 g shock survival
or shock. Its high resolution (3.9 mg/LSB) enables measurement
Small, thin Pb free, RoHS compliant 3 mm × 3 mm × 0.95 mm
of inclination changes less than 1.0°.
LGA package
Several special sensing functions are provided. Activity and inactivity sensing detect the presence or lack of motion. Tap
sensing detects single and double taps in any direction. Free-fall
Handsets
sensing detects if the device is falling. Orientation detection
Gaming and pointing devices
reports four- and six-position orientation and can trigger an
Hard disk drive (HDD) protection
interrupt upon change in orientation. These functions can be mapped individual y to either of two interrupt output pins. An integrated memory management system with a 32-level first in, first out (FIFO) buffer can be used to store data to minimize host processor activity and lower overall system power consumption. The ADXL344 is supplied in a small, thin, 3 mm × 3 mm × 0.95 mm, 16-terminal, plastic package.
FUNCTIONAL BLOCK DIAGRAM VS VDD I/O ADXL344 POWER MANAGEMENT CONTROL INT1 SENSE ADC AND ELECTRONICS DIGITAL INTERRUPT 3-AXIS FILTER LOGIC INT2 SENSOR SDA/SDI/SDIO 32-LEVEL SERIAL I/O FIFO SDO/ALT ADDRESS SCL/SCLK
001
GND CS
10628- Figure 1.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2012 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Package Information ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Power Sequencing Power Savings Power Modes Autosleep Mode Standby Mode Serial Communications SPI Preventing Bus Traffic Errors I2C Interrupts DATA_READY Bit SINGLE_TAP Bit DOUBLE_TAP Bit Activity Bit Inactivity Bit FREE_FALL Bit Watermark Bit Overrun Bit Orientation Bit FIFO Bypass Mode FIFO Mode Stream Mode Trigger Mode Retrieving Data from FIFO Self-Test Register Map Register Definitions Register 0x00—DEVID (Read Only) Register 0x1D—THRESH_TAP (Read/Write) Register 0x1E, Register 0x1F, Register 0x20—OFSX, OFSY, OFSZ (Read/Write) Register 0x21—DUR (Read/Write) Register 0x22—Latent (Read/Write) Register 0x23—Window (Read/Write) Register 0x24—THRESH_ACT (Read/Write) Register 0x25—THRESH_INACT (Read/Write) Register 0x26—TIME_INACT (Read/Write) Register 0x27—ACT_INACT_CTL (Read/Write) ACT AC/DC and INACT AC/DC Bits ACT_x Enable Bits and INACT_x Enable Bits Register 0x28—THRESH_FF (Read/Write) Register 0x29—TIME_FF (Read/Write) Register 0x2A—TAP_AXES (Read/Write) Improved Tap Bit Suppress Bit TAP_x Enable Bits Register 0x2B—ACT_TAP_STATUS (Read Only) ACT_x Source and TAP_x Source Bits Asleep Bit Register 0x2C—BW_RATE (Read/Write) LOW_POWER Bit Rate Bits Register 0x2D—POWER_CTL (Read/Write) Link Bit AUTO_SLEEP Bit Measure Bit Sleep Bit Wakeup Bits Register 0x2E—INT_ENABLE (Read/Write) Register 0x2F—INT_MAP (Read/Write) Register 0x30—INT_SOURCE (Read Only) Register 0x31—DATA_FORMAT (Read/Write) SELF_TEST Bit SPI Bit INT_INVERT Bit FULL_RES Bit Justify Bit Range Bits Register 0x32 to Register 0x37—DATAX0, DATAX1, DATAY0, DATAY1, DATAZ0, DATAZ1 (Read Only) Register 0x38—FIFO_CTL (Read/Write) FIFO_MODE Bits Trigger Bit Samples Bits Register 0x39—FIFO_STATUS (Read Only) FIFO_TRIG Bit Entries Bits Register 0x3A—TAP_SIGN (Read Only) xSIGN Bits xTAP Bits Register 0x3B—ORIENT_CONF (Read/Write) INT_ORIENT Bit Dead Zone Bits INT_3D Bit Divisor Bits Register 0x3C—Orient (Read Only) Vx Bits xD_ORIENT Bits Applications Information Power Supply Decoupling Mechanical Considerations for Mounting Tap Detection Improved Tap Detection Tap Sign Threshold Link Mode Sleep Mode vs. Low Power Mode Offset Calibration Using Self-Test Orientation Sensing Data Formatting of Upper Data Rates Noise Performance Operation at Voltages Other Than 2.6 V Offset Performance at Lowest Data Rates Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
