Datasheet ADIS16228 (Analog Devices) - 2
DescriptionDigital Triaxial Vibration Sensor with FFT Analysis and Storage
Pages / Page29 / 2 — ADIS16228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
ADIS16228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16228* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16228 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16ACL1 Breakout Board • Symbols and Footprints • EVAL-ADIS Evaluation System • EVAL-ADIS2 Evaluation System
DISCUSSIONS
View all ADIS16228 EngineerZone Discussions.
DOCUMENTATION Data Sheet SAMPLE AND BUY
• ADIS16228: Digital Triaxial Vibration Sensor with FFT Visit the product page to see pricing options. Analysis and Storage Data Sheet
User Guides TECHNICAL SUPPORT
• PC-Based Evaluation of the ADIS16228 Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS THEORY OF OPERATION SENSING ELEMENT SIGNAL PROCESSING USER INTERFACE SPI Interface Dual-Memory Structure BASIC OPERATION SPI WRITE COMMANDS SPI READ COMMANDS DATA RECORDING AND SIGNAL PROCESSING RECORDING MODE Manual FFT Mode Automatic FFT Mode Manual Time Capture Mode Real-Time Mode SPECTRAL RECORD PRODUCTION SAMPLE RATE/FILTERING DYNAMIC RANGE/SENSITIVITY Frequency Response Correction Axial Definitions Dynamic Range Settings Scale Adjustment PRE-FFT WINDOWING FFT FFT Averaging RECORDING TIMES DATA RECORDS FFT RECORD FLASH ENDURANCE SPECTRAL ALARMS ALARM DEFINITION Alarm Band Frequency Definitions Alarm Trigger Settings Enable Alarm Settings ALARM INDICATOR SIGNALS ALARM FLAGS AND CONDITIONS ALARM STATUS WORST-CASE CONDITION MONITORING READING OUTPUT DATA READING DATA FROM THE DATA BUFFER ACCESSING FFT RECORD DATA DATA FORMAT REAL-TIME DATA COLLECTION POWER SUPPLY/TEMPERATURE FFT EVENT HEADER SYSTEM TOOLS GLOBAL COMMANDS STATUS/ERROR FLAGS POWER-DOWN OPERATION MANAGMENT Software Busy Indicator Software Escape Code INPUT/OUTPUT FUNCTIONS Busy Indicator Trigger Input Alarm Indicator General-Purpose Input/Output SELF-TEST FLASH MEMORY MANAGEMENT DEVICE IDENTIFICATION APPLICATIONS INFORMATION INTERFACE BOARD FLEX CONNECTOR CARE MATING CONNECTOR OUTLINE DIMENSIONS ORDERING GUIDE
