Datasheet ADXL206 (Analog Devices) - 5
DescriptionPrecision, ±5 g, Dual-Axis, High Temperature iMEMS Accelerometer
Pages / Page13 / 5 — ADXL206. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL …
File Format / SizePDF / 453 Kb
ADXL206. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter Rating. Table 3. Thermal Resistance
ADXL206 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter Rating Table 3 Thermal Resistance
ADXL206 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, for a device Acceleration (Any Axis) soldered in a printed circuit board (PCB) for surface-mount Unpowered 500 g packages. Powered 500 g
VS −0.3 V to +7.0 V
Package Type θ
All Other Pins (COM − 0.3 V) to (V
JA θJC Unit
S + 0.3 V) Output Short-Circuit Duration Indefinite 8-Lead SBDIP 120 20 °C/W (Any Pin to Common) Ambient Operating Temperature −55°C to +175°C Range (T
ESD CAUTION
A) Storage Temperature Range −65°C to +200°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability.
CRITICAL ZONE tP TL TO TP TP RAMP-UP E TL R T tL U SMAX T A TSMIN PER EM T tS PREHEAT RAMP-DOWN
02 0
TIME 25°C TO PEAK
0- 60
TIME
09 Figure 2. Recommended Soldering Profile
Table 4. Recommended Soldering Profile Limits Profile Feature Sn63/Pb37 Pb-Free
Average Ramp Rate (TL to TP) 3°C/sec max 3°C/sec max Preheat Minimum Temperature (TSMIN) 100°C 150°C Maximum Temperature (TSMAX) 150°C 200°C Time (TSMIN to TSMAX), tS 60 sec to 120 sec 60 sec to 150 sec Ramp-Up Rate (TSMAX to TL) 3°C/sec max 3°C/sec max Time Maintained Above Liquidous (tL) 60 sec to 150 sec 60 sec to 150 sec Liquidous Temperature (TL) 183°C 217°C Peak Temperature (TP) 240°C + 0°C/−5°C 260°C + 0°C/−5°C Time Within 5°C of Actual Peak Temperature (tP) 10 sec to 30 sec 20 sec to 40 sec Ramp-Down Rate (TP to TL) 6°C/sec max 6°C/sec max Time 25°C to Peak Temperature 6 minutes max 8 minutes max Rev. B | Page 4 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF-TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: NOISE/BANDWIDTH TRADE-OFF USING THE ADXL206 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL206 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt OUTLINE DIMENSIONS ORDERING GUIDE
