Datasheet ADXL206 (Analog Devices) - 9
DescriptionPrecision, ±5 g, Dual-Axis, High Temperature iMEMS Accelerometer
Pages / Page13 / 9 — ADXL206. Data Sheet. ( 20. TION. U 15. T OF P. T OF P 10. –40. –30. –20. …
File Format / SizePDF / 453 Kb
ADXL206. Data Sheet. ( 20. TION. U 15. T OF P. T OF P 10. –40. –30. –20. –10. OUTPUT BIAS DRIFT (mV). 100. 0.9. VS = 5V. S = 5V. 0.8. % (. 0.7. mA) (. 0.6
ADXL206 Data Sheet ( 20 TION U 15 T OF P T OF P 10 –40 –30 –20 –10 OUTPUT BIAS DRIFT (mV) 100 0.9 VS = 5V S = 5V 0.8 % ( 0.7 mA) ( 0.6
ADXL206 Data Sheet 25 25 ) ) % % ( 20 ( 20 TION TION LA LA U 15 U 15 OP OP T OF P 10 T OF P 10 N N E E C C R R E E P 5 P 5 0 0 –40 –30 –20 –10 0 10 20
018
–20 –10 0 10
019
09600-
09600- Figure 16. X-Axis Zero g Output Bias Drift over 1000 Hours Figure 18. Y-Axis Zero g Output Bias Drift over 1000 Hours at TA = 175°C, Powered at TA = 175°C, Powered
100 0.9 VS = 5V V 90 S = 5V ) 0.8 80 % ( 70 TION 0.7 LA 60 U mA) ( OP 50 NT 0.6 40 T OF P N CURRE E 0.5 30 C R E P 20 0.4 10 0 0.3 200 300 400 500 600 700 800 900 1000
013
–50 0 50 100 150
012
CURRENT (µA)
09600-
AMBIENT TEMPERATURE (°C)
09600- Figure 17. Supply Current at TA = 25°C Figure 19. Supply Current vs. Temperature Rev. B | Page 8 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF-TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: NOISE/BANDWIDTH TRADE-OFF USING THE ADXL206 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL206 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt OUTLINE DIMENSIONS ORDERING GUIDE
