Datasheet ADXL337 (Analog Devices) - 8
DescriptionSmall, Low Power, 3-Axis ±3 g Accelerometer
Pages / Page17 / 8 — 1.60. 1.58. 1.56. ION T. 1.54. V 1.52. ( T. 1.50. OU 1.48. RCE. 1.46. E …
File Format / SizePDF / 332 Kb
1.60. 1.58. 1.56. ION T. 1.54. V 1.52. ( T. 1.50. OU 1.48. RCE. 1.46. E P. 1.44. 1.42. 1.40. –40. –20. 100. –2. –1. –0. TEMPERATURE (°C)
1.60 1.58 1.56 ION T 1.54 V 1.52 ( T 1.50 OU 1.48 RCE 1.46 E P 1.44 1.42 1.40 –40 –20 100 –2 –1 –0 TEMPERATURE (°C)
ADXL337
45 1.60 40 1.58 35 1.56 ION T 1.54 A 30 UL ) P V 1.52 O 25 ( T P U F 1.50 P O 20 T NT OU 1.48 15 RCE 1.46 E P 10 1.44 5 1.42 0 1.40 0
4
50 25 00 75 50 25 00 75 50 25 25 50 75 00 –40 –20 0 20 40 60 80 100
01 1 1 8-
–2. –2. –2. –1. –1. –1. –1. –0. –0. –0. 0. 0. 0. 1.
0
TEMPERATURE (°C)
35 8- 09
TEMPERATURE COEFFICIENT (mg /°C)
35 09 Figure 9. X-Axis Zero g Bias Temperature Coefficient, VS = 3 V Figure 12. X-Axis Zero g Bias vs. Temperature—Eight Parts Soldered to PCB
35 1.60 1.58 30 1.56 ION 25 T 1.54 A UL ) P V 1.52 20 O ( T P U F 1.50 O TP 15 NT OU 1.48 RCE 10 1.46 E P 1.44 5 1.42 0 1.40 0 50 25 00 75 50 25 00 75 50 25 25 50 75 00 –40 –20 0 20 40 60 80 100
15 2 0 8-
01 8-
TEMPERATURE (°C)
35
09
g /°C)
35 09 Figure 10. Y-Axis Zero g Bias Temperature Coefficient, VS = 3 V Figure 13. Y-Axis Zero g Bias vs. Temperature—Eight Parts Soldered to PCB
30 1.60 1.58 25 1.56 TION 1.54 A 20 L ) PU V 1.52 ( T PO 15 U F 1.50 O TP T OU 1.48 EN C 10 1.46 PER 1.44 5 1.42 0 1.40 0 5 0 5 0 5 0 5 0 5 0 5 0
6
–60 –40 –20 0 20 40 60 80 100
1 0
0. 1. 1. 2. 2. 3.
8- 13
–3. –2. –2. –1. –1. –0.
-0
TEMPERATURE (°C)
35 09
58 93 0 Figure 11. Z-Axis Zero g Bias Temperature Coefficient, VS = 3 V Figure 14. Z-Axis Zero g Bias vs. Temperature—Eight Parts Soldered to PCB Rev. 0 | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL SENSOR PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX, CY, AND CZ SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USE WITH OPERATING VOLTAGES OTHER THAN 3 V AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
