Datasheet ADXL325 (Analog Devices) - 9 Manufacturer Analog Devices Description Small, Low Power, 3-Axis ±5 g Accelerometer Pages / Page 17 / 9 — ADXL325. N = 8. 0.187. 0.182. ( 0.177. Y T. TIO A. IVI. T 0.172. P PO. … File Format / Size PDF / 283 Kb Document Language English
ADXL325. N = 8. 0.187. 0.182. ( 0.177. Y T. TIO A. IVI. T 0.172. P PO. SEN 0.167. 0.162. 0.157. 0.164. 0.166. 0.168. 0.170. 0.172. 0.174. 0.176. 0.178. 0.180
Model Line for this Datasheet Text Version of Document ADXL325 30 N = 8 0.187 25 0.182 ) ) 20 g (% V/ N ( 0.177 Y T TIO A 15 IVI L T 0.172 U SI P PO 10 SEN 0.167 5 0.162 0 0.157 0.164 0.166 0.168 0.170 0.172 0.174 0.176 0.178 0.180 0.182 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100 20 17 -0 -0 46 46SENSITIVITY (V/ TEMPERATURE (°C) g ) 79 79 0 0 Figure 15. X-Axis Sensitivity at 25°C, VS = 3 V Figure 18. X-Axis Sensitivity vs. Temperature, Eight Parts Soldered to PCB, VS = 3 V40 N = 8 35 0.187 30 0.182 ) ) % /g ( 25 V ( 0.177 Y ON IT TI A 20 IV L IT 0.172 S PU N 15 E PO S 0.167 10 0.162 5 0 0.157 80.164 0.166 0.168 0.170 0.172 0.174 0.176 0.178 0.180 0.182 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100 21 0 01 6- 6-SENSITIVITY (V/ 94g ) 94TEMPERATURE (°C) 07 07 Figure 16. Y-Axis Sensitivity at 25°C, VS = 3 V Figure 19. Y-Axis Sensitivity vs. Temperature, Eight Parts Soldered to PCB, VS = 3 V35 0.187 N = 8 30 0.182 25 ) 0.177 % /g) ( V 20 ( ON Y TI IT 0.172 A IV L 15 IT S PU N E PO S 0.167 10 0.162 5 0 0.157 20.164 0.166 0.168 0.170 0.172 0.174 0.176 0.178 0.180 0.182 19–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100 0 02 6- 6-SENSITIVITY (V/ 94g ) 94TEMPERATURE (°C) 07 07 Figure 17. Z-Axis Sensitivity at 25°C, VS = 3 V Figure 20. Z-Axis Sensitivity vs. Temperature, Eight Parts Soldered to PCB, VS = 3 V Rev. 0 | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL SENSOR PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX, CY, AND CZ SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USE WITH OPERATING VOLTAGES OTHER THAN 3 V AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
