Datasheet ADIS16240 (Analog Devices) - 2
DescriptionLow Power Programmable Impact Sensor and Recorder
Pages / Page21 / 2 — ADIS16240* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 454 Kb
ADIS16240* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16240* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16240 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16240 Daughter Board • Symbols and Footprints • ADISUSB Evaluation System
DISCUSSIONS DOCUMENTATION
View all ADIS16240 EngineerZone Discussions.
Data Sheet
• ADIS16240: Low Power, Programmable Impact Sensor
SAMPLE AND BUY
and Recorder Data Sheet Visit the product page to see pricing options.
User Guides
• UG-363: ADISUSB User Guide
TECHNICAL SUPPORT
Submit a technical question or find your regional support
SOFTWARE AND SYSTEMS REQUIREMENTS
number. • ADIS16240 IIO Programmable Impact Sensor and Recorder Linux Driver
DOCUMENT FEEDBACK
• ADIS16240 Evaluation Software for the ADISUSB Submit feedback for this data sheet.
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Sensing Element Data Sampling and Processing User Interface SPI Interface User Registers Capture Basic Operation SPI Write Commands Memory Map Output Data Registers Processing Sensor Data Event Recorder Internal Trigger Setup External Trigger Setup Buffer Memory Configuration Event Organization Reading Event Data Transient Behavior During Capture Operational Control Internal Sample Rate Global Commands Input/Output Lines Offset Adjustment Diagnostics Clock Checksum Flash Memory Endurance Management Applications Information Assembly Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
