Datasheet ADXL335 (Analog Devices) - 5
DescriptionSmall, Low Power, 3-Axis ±3 g Accelerometer
Pages / Page17 / 5 — ADXL335. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating. ESD CAUTION
RevisionB
File Format / SizePDF / 384 Kb
ADXL335 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
ADXL335 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Acceleration (Any Axis, Unpowered) 10,000 g rating only; functional operation of the device at these or any Acceleration (Any Axis, Powered) 10,000 g other conditions above those indicated in the operational V section of this specification is not implied. Exposure to absolute S −0.3 V to +3.6 V All Other Pins (COM − 0.3 V) to (V maximum rating conditions for extended periods may affect S + 0.3 V) Output Short-Circuit Duration Indefinite device reliability. (Any Pin to Common) Temperature Range (Powered) −55°C to +125°C Temperature Range (Storage) −65°C to +150°C
ESD CAUTION
Rev. B | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL SENSOR PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX, CY, AND CZ SELF-TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USE WITH OPERATING VOLTAGES OTHER THAN 3 V AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
