Datasheet ADXL335 (Analog Devices) - 9
DescriptionSmall, Low Power, 3-Axis ±3 g Accelerometer
Pages / Page17 / 9 — ADXL335. 0.320. N = 8. 0.315. 0.310. 0.305. A L. Y ( T. 0.300. IVI T. PO …
File Format / SizePDF / 384 Kb
ADXL335. 0.320. N = 8. 0.315. 0.310. 0.305. A L. Y ( T. 0.300. IVI T. PO F. 0.295. SEN. 0.290. 0.285. 0.280
ADXL335 0.320 N = 8 0.315 0.310 0.305 A L Y ( T 0.300 IVI T PO F 0.295 SEN 0.290 0.285 0.280
ADXL335 20 0.320 N = 8 0.315 15 0.310 N ) IO g T 0.305 V/ A L Y ( T PU 10 0.300 IVI T PO F SI O 0.295 % SEN 5 0.290 0.285 0 0.280 0.285 0.288 0.291 0.294 0.297 0.300 0.303 0.306 0.309 0.312 0.315
17 0 0
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100
02 8- 8-
SENSITIVITY (V/g )
780
TEMPERATURE (°C)
80 0 07 Figure 15. X-Axis Sensitivity at 25°C, VS = 3 V Figure 18. X-Axis Sensitivity vs. Temperature— Eight Parts Soldered to PCB, VS = 3 V
25 0.320 N = 8 0.315 20 0.310 ) /g TION 0.305 V A 15 ( L Y U IT 0.300 OP IV P IT 10 S N OF 0.295 E % S 0.290 5 0.285 0 0.280 0.285 0.288 0.291 0.294 0.297 0.300 0.303 0.306 0.309 0.312 0.315
18
21 -0 0 08 8-
SENSITIVITY (V/g )
78
TEMPERATURE (°C)
80 0 07 Figure 16. Y-Axis Sensitivity at 25°C, VS = 3 V Figure 19. Y-Axis Sensitivity vs. Temperature— Eight Parts Soldered to PCB, VS = 3 V
25 0.320 N = 8 0.315 20 0.310 N ) IO /g T 0.305 V A 15 ( L Y PU IT 0.300 PO ITIV F 10 S N O 0.295 E % S 0.290 5 0.285 0 0.280 0.285 0.288 0.291 0.294 0.297 0.300 0.303 0.306 0.309 0.312 0.315
19 2 0
8- -02
SENSITIVITY (V/g )
80 08 07
TEMPERATURE (°C)
78 0 Figure 17. Z-Axis Sensitivity at 25°C, VS = 3 V Figure 20. Z-Axis Sensitivity vs. Temperature— Eight Parts Soldered to PCB, VS = 3 V Rev. B | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL SENSOR PERFORMANCE APPLICATIONS INFORMATION POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX, CY, AND CZ SELF-TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USE WITH OPERATING VOLTAGES OTHER THAN 3 V AXES OF ACCELERATION SENSITIVITY LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
