Datasheet ADXL103, ADXL203 (Analog Devices) - 10
DescriptionPrecision ±1.7 g, ±5 g, ±18 g Dual-Axis iMEMS® Accelerometer
Pages / Page16 / 10 — ADXL103/ADXL203. Data Sheet. AD22035. AND AD22037. TION. A 40. PO 30. EN …
RevisionF
File Format / SizePDF / 867 Kb
ADXL103/ADXL203. Data Sheet. AD22035. AND AD22037. TION. A 40. PO 30. EN 20. PER. –50. –40. –30. –20. –10. ZERO g. BIAS (mV). PU 20. O 15. –3. –2. –1. –0
ADXL103/ADXL203 Data Sheet AD22035 AND AD22037 TION A 40 PO 30 EN 20 PER –50 –40 –30 –20 –10 ZERO g BIAS (mV) PU 20 O 15 –3 –2 –1 –0
ADXL103/ADXL203 Data Sheet AD22035 AND AD22037 60 60 50 50 TION TION A 40 A 40 L L PU PU PO 30 PO 30 F F O O T T EN 20 EN C 20 C PER PER 10 10 0 0 0 0 10 20 30 40 50
105
4 0 10 20 30 40 50
108
–50 –40 –30 –20 –10 –50 –30 –20 –10 ZERO g BIAS (mV)
03757- 03757-
ZERO g BIAS (mV)
Figure 25. X-Axis Zero g Bias Deviation from Ideal at 25°C Figure 28. Y-Axis Zero g Bias Deviation from Ideal at 25°C
35 35 30 30 25 25 TION TION A A L L PU 20 PU 20 PO PO F F O 15 O T 15 T EN EN C C 10 10 PER PER 5 5 0 0 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 0. 1. 1. 2. 2. 3. 3. 0. 1. 1. 2. –3. –2. –2. –1. –1. –0.
106
2. 3. –3. –2. –2. –1. –1. –0.
009
TEMPERATURE COEFFICIENT (mg /°C)
03757-
03757- Figure 26. X-Axis Zero g Bias Temperature Coefficient Figure 29. Y-Axis Zero g Bias Temperature Coefficient
25 25 20 20 TION A TION L A L 15 PU 15 PU PO F PO F O T O 10 T 10 EN C EN C PER PER 5 5 0 0 97 98 99 100 101 102 103
107
97 98 99
10
100 101 102 103
1
SENSITIVITY (mV/g)
03757-
SENSITIVITY (mV/g)
03757- Figure 27. X-Axis Sensitivity at 25°C Figure 30. Y-Axis Sensitivity at 25°C Rev. E | Page 10 of 16 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ADXL103 and ADXL203 AD22293 AD22035 and AD22037 All Models Theory of Operation Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX and CY Self Test Design Trade-Offs for Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Using the ADXL103/ADXL203 with Operating Voltages Other than 5 V Using the ADXL203 as a Dual-Axis Tilt Sensor Dual-Axis Tilt Sensor: Converting Acceleration to Tilt Outline Dimensions Ordering Guide Automotive Products
