Datasheet AD7740 (Analog Devices) - 6
Description3 V/5 V Low Power, Synchronous Voltage-to-Frequency Converter
Pages / Page13 / 6 — AD7740. TERMINOLOGY. POWER SUPPLY REJECTION RATIO (PSRR). INTEGRAL …
RevisionC
File Format / SizePDF / 330 Kb
AD7740. TERMINOLOGY. POWER SUPPLY REJECTION RATIO (PSRR). INTEGRAL NONLINEARITY. OUTPUT. FREQUENCY. OFFSET ERROR. FOUT. 0.9 fCLKIN
AD7740 TERMINOLOGY POWER SUPPLY REJECTION RATIO (PSRR) INTEGRAL NONLINEARITY OUTPUT FREQUENCY OFFSET ERROR FOUT 0.9 fCLKIN
This indicates how the apparent input voltage of the VFC is For the VFC, Integral Nonlinearity (INL) is a measure of the maxi- affected by changes in the supply voltage. The input voltage is mum deviation from a straight line passing through the actual kept constant at 2 V, VREF is 2.5 V and the VDD supply is varied endpoints of the VFC transfer function. The error is expressed in ⫾10% at 3.3 V and ±5% at 5 V. The ratio of the apparent change % of the actual frequency span: in input voltage to the change in VDD is measured in dBs. Frequency Span = FOUT(max) – FOUT(min)
Ideally, the output frequency for 0 V input voltage is 10% of
0.9 fCLKIN
f
GAIN ERROR
CLKIN in unbuffered mode. The deviation from this value referred to the input is the offset error at BUF = 0. In buffered mode the minimum output frequency (corresponding to 0.10 V minimum input voltage) is 13.2% of fCLKIN at VREF = 2.5 V. The deviation
IDEAL
from this value referred to the input is the offset error at BUF = 1.
WITH OFFSET ERROR ONLY
Offset error is expressed in mV.
WITH OFFSET ERROR AND GAIN ERROR GAIN ERROR 0.1
This is a measure of the span error of the VFC. The gain is the
fCLKIN INPUT
scale factor that relates the input VIN to the output FOUT.
VOLTAGE 0
The gain error is the deviation in slope of the actual VFC transfer
OFFSET REFIN VIN ERROR
characteristic from the ideal expressed as a percentage of the full- scale span. See Figure 2. Figure 2. Offset and Gain
OFFSET ERROR DRIFT
This is a measure of the change in Offset Error with changes in temperature. It is expressed in µV/°C.
GAIN ERROR DRIFT
This is a measure of the change in Gain Error with changes in temperature. It is expressed in (ppm of span)/°C. REV. C – 5 –
