Datasheet ADIS16445 (Analog Devices) - 2
DescriptionCompact, Precision Six Degrees of Freedom Inertial Sensor
Pages / Page23 / 2 — ADIS16445* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. …
RevisionI
File Format / SizePDF / 499 Kb
ADIS16445* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADIS16445* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Technical Articles
• Designing For Low Noise Feedback Control With Mems
EVALUATION KITS
Gyroscopes • ADIS16445 Daughter Board • ADIS1644X Flex Cable
DESIGN RESOURCES
• ADIS16IMU2 Breakout Board • ADIS16445 Material Declaration • EVAL-ADIS Evaluation System • PCN-PDN Information • EVAL-ADIS2 Evaluation System • Quality And Reliability • Symbols and Footprints
DOCUMENTATION Application Notes DISCUSSIONS
• AN-1305: ADIS16445/ADIS16448 Mechanical Design View all ADIS16445 EngineerZone Discussions. Guidelines and Examples
Data Sheet SAMPLE AND BUY
• ADIS16445: Compact, Precision Six Degrees of Freedom Visit the product page to see pricing options. Inertial Sensor Data Sheet
User Guides TECHNICAL SUPPORT
• ADIS1644x Evaluation on the EVAL-ADIS System Submit a technical question or find your regional support number.
SOFTWARE AND SYSTEMS REQUIREMENTS
• ADIS16400 IIO Inertial Measurement Unit Linux Driver
DOCUMENT FEEDBACK
• IMU Evaluation Software for the EVAL-ADISx Platforms Submit feedback for this data sheet. • USB Driver File for EVAL-ADISx Platforms (v2.2.95.68, 3/9/2016)
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics User Registers User Interface Reading Sensor Data Burst Read Function SPI Read Test Sequence Device Configuration Dual Memory Structure Output Data Registers Gyroscopes Accelerometers Internal Temperature System Functions Global Commands Product Identification Self-Test Function Status/Error Flags Memory Management Checksum Test Input/Output Configuration Data Ready Indicator General-Purpose Input/Output Example Input/Output Configuration Digital Processing Configuration Gyroscopes/Accelerometers Input Clock Configuration Digital Filtering Dynamic Range Calibration Gyroscopes Gyroscope Bias Error Estimation Gyroscope Bias Correction Factors Single Command Bias Correction Accelerometers Accelerometer Bias Error Estimation Accelerometer Bias Correction Factors Point of Percussion Alignment Flash Updates Restoring Factory Calibration Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example Applications Information Mounting Tips Power Supply Considerations ADIS16445/PCBZ Installation PC-Based Evaluation Tools Outline Dimensions Ordering Guide
