ADIS16448* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Press • 10-DoF MEMS IMU Incorporates Sensor Fusion Algorithm EVALUATION KITS for Exceptionally Precise Orientation Sensing in Industrial, Defense and Avionics Applications • ADIS16448 Daughter Board Technical Articles • ADIS1644X Flex Cable • Designing For Low Noise Feedback Control With Mems • ADIS16IMU2 Breakout Board Gyroscopes • EVAL-ADIS Evaluation System • EVAL-ADIS2 Evaluation System DESIGN RESOURCES • ADIS16448 Material Declaration DOCUMENTATION • PCN-PDN Information Application Notes • Quality And Reliability • AN-1305: ADIS16445/ADIS16448 Mechanical Design • Symbols and Footprints Guidelines and Examples Data SheetDISCUSSIONS • ADIS16448 Silicon Anomaly View all ADIS16448 EngineerZone Discussions. • ADIS16448: Compact, Precision Ten Degrees of Freedom Inertial Sensor Data Sheet SAMPLE AND BUYUser Guides Visit the product page to see pricing options. • ADIS1644x Evaluation on the EVAL-ADIS System SOFTWARE AND SYSTEMS REQUIREMENTSTECHNICAL SUPPORT Submit a technical question or find your regional support • ADIS16400 IIO Inertial Measurement Unit Linux Driver number. • IMU Evaluation Software for the EVAL-ADISx Platforms • USB Driver File for EVAL-ADISx Platforms (v2.2.95.68, DOCUMENT FEEDBACK 3/9/2016) Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS USER REGISTERS USER INTERFACE READING SENSOR DATA Burst Read Function Burst Read Function with CRC SPI Read Test Sequence DEVICE CONFIGURATION Dual Memory Structure OUTPUT DATA REGISTERS GYROSCOPES ACCELEROMETERS MAGNETOMETERS BAROMETRIC PRESSURE REMOTE PRESSURE SENSING INTERNAL TEMPERATURE SYSTEM FUNCTIONS GLOBAL COMMANDS PRODUCT IDENTIFICATION SELF-TEST FUNCTION STATUS/ERROR FLAGS Magnetometer/Barometer New Data Indicator MEMORY MANAGEMENT Checksum Test INPUT/OUTPUT CONFIGURATION DATA READY INDICATOR GENERAL-PURPOSE INPUT/OUTPUT Example Input/Output Configuration DIGITAL PROCESSING CONFIGURATION GYROSCOPES/ACCELEROMETERS INPUT CLOCK CONFIGURATION Digital Filtering Dynamic Range MAGNETOMETER/BAROMETER New Data Indicators CALIBRATION GYROSCOPES Gyroscope Bias Error Estimation Gyroscope Bias Correction Factors Single Command Bias Correction ACCELEROMETERS Accelerometer Bias Error Estimation Accelerometer Bias Correction Factors Point of Percussion Alignment MAGNETOMETER CALIBRATION Hard Iron Correction Hard Iron Factors Soft Iron Effects FLASH UPDATES RESTORING FACTORY CALIBRATION ALARMS STATIC ALARM USE DYNAMIC ALARM USE ALARM REPORTING Alarm Example APPLICATIONS INFORMATION MOUNTING TIPS POWER SUPPLY CONSIDERATIONS ADIS16IMU2/PCBZ PC-BASED EVALUATION TOOLS OUTLINE DIMENSIONS ORDERING GUIDE
