Datasheet ADIS16480 (Analog Devices) - 3
DescriptionTen Degrees of Freedom MEMS Inertial Sensor with Dynamic Orientation Outputs
Pages / Page45 / 3 — ADIS16480. Data Sheet. TABLE OF CONTENTS
RevisionH
File Format / SizePDF / 937 Kb
ADIS16480 Data Sheet TABLE OF CONTENTS
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 5 link to page 8 link to page 10 link to page 10 link to page 11 link to page 12 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 15 link to page 19 link to page 19 link to page 19 link to page 20 link to page 20 link to page 21 link to page 22 link to page 22 link to page 22 link to page 23 link to page 24 link to page 24 link to page 25 link to page 26 link to page 26 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 30 link to page 30 link to page 30 link to page 31 link to page 31 link to page 32 link to page 32 link to page 34 link to page 34 link to page 35 link to page 35 link to page 37 link to page 37 link to page 37 link to page 38 link to page 38 link to page 38 link to page 40 link to page 40 link to page 40 link to page 41 link to page 41 link to page 43 link to page 43 link to page 44 link to page 44 link to page 45 link to page 45
Features .. 1 Gyroscopes/Accelerometers ... 26 Applications ... 1 Averaging/Decimation Filter .. 26 General Description ... 1 Magnetometer/Barometer ... 26 Functional Block Diagram .. 1 FIR Filter Banks .. 27 Revision History ... 3 Extended Kalman Filter ... 29 Specifications ... 4 Algorithm .. 29 Timing Specifications .. 7 Covariance Terms ... 29 Absolute Maximum Ratings .. 9 Reference Frame ... 30 ESD Caution .. 9 Reference Transformation Matrix .. 30 Pin Configuration and Function Descriptions ... 10 Declination .. 31 Typical Performance Characteristics ... 11 Adaptive Operation .. 31 Basic Operation ... 12 Calibration ... 33 Register Structure ... 12 Gyroscopes .. 33 SPI Communication ... 13 Accelerometers ... 34 Device Configuration .. 13 Magnetometers ... 34 Reading Sensor Data .. 13 Barometers .. 36 User Registers .. 14 Restoring Factory Calibration .. 36 Output Data Registers .. 18 Point of Percussion Alignment ... 36 Inertial Sensor Data Format .. 18 Alarms .. 37 Rotation Rate (Gyroscope) .. 18 Static Alarm Use ... 37 Acceleration ... 19 Dynamic Alarm Use .. 37 Delta Angles .. 19 System Controls .. 39 Delta Velocity .. 20 Global Commands ... 39 Magnetometers ... 21 Memory Management ... 39 Roll, Pitch, Yaw Angles .. 21 General-Purpose I/O ... 40 Initial Conditions ... 21 Power Management ... 40 Rotation Matrix Data ... 22 Applications Information .. 42 Barometer .. 23 Mounting Tips .. 42 Internal Temperature ... 23 Evaluation Tools ... 43 Status/Alarm Indicators ... 24 Power Supply Considerations ... 43 Firmware Revision ... 25 Outline Dimensions ... 44 Product Identification .. 25 Ordering Guide .. 44 Digital Signal Processing ... 26 Rev. G | Page 2 of 44 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Delta Velocity Magnetometers Roll, Pitch, Yaw Angles Initial Conditions Quaternion Euler Angles Rotation Matrix Data Barometer Internal Temperature Status/Alarm Indicators Firmware Revision Product Identification Digital Signal Processing Gyroscopes/Accelerometers Averaging/Decimation Filter Magnetometer/Barometer FIR Filter Banks Filter Memory Organization Default Filter Performance Extended Kalman Filter Algorithm Covariance Terms Reference Frame Reference Transformation Matrix Declination Adaptive Operation Adaptive EKF Enable Bit Automatic EKF Divergence Reset Control Bit Gyroscope Fade Control Bit Body Frame/Local Navigation Frame Bit Orientation Format Control Bit Magnetometer Disable Control Bit Gravity Removal Control Bit Linear Acceleration/Magnetic Disturbance Detection Calibration Gyroscopes Manual Bias Correction Manual Sensitivity Correction Linear Acceleration on Effect on Gyroscope Bias Accelerometers Manual Bias Correction Manual Sensitivity Correction Magnetometers Hard Iron Correction Soft Iron Correction Matrix Barometers Restoring Factory Calibration Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Example System Controls Global Commands Software Reset Automatic Self-Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management General-Purpose Registers Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU1/PCB PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
