Datasheet ADIS16480 (Analog Devices) - 9
DescriptionTen Degrees of Freedom MEMS Inertial Sensor with Dynamic Orientation Outputs
Pages / Page45 / 9 — ADIS16480. Data Sheet. tSTALL. SCLK. SYNC. CLOCK (CLKIN). DATA. READY. …
RevisionH
File Format / SizePDF / 937 Kb
ADIS16480. Data Sheet. tSTALL. SCLK. SYNC. CLOCK (CLKIN). DATA. READY. OUTPUT. DATA VALID. REGISTERS
ADIS16480 Data Sheet tSTALL SCLK SYNC CLOCK (CLKIN) DATA READY OUTPUT DATA VALID REGISTERS
ADIS16480 Data Sheet tSTALL CS
003
SCLK
10278- Figure 3. Stall Time and Data Rate
t2 t3 t1 SYNC CLOCK (CLKIN) DATA READY
004
OUTPUT DATA VALID DATA VALID REGISTERS
10278- Figure 4. Input Clock Timing Diagram Rev. G | Page 8 of 44 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Delta Velocity Magnetometers Roll, Pitch, Yaw Angles Initial Conditions Quaternion Euler Angles Rotation Matrix Data Barometer Internal Temperature Status/Alarm Indicators Firmware Revision Product Identification Digital Signal Processing Gyroscopes/Accelerometers Averaging/Decimation Filter Magnetometer/Barometer FIR Filter Banks Filter Memory Organization Default Filter Performance Extended Kalman Filter Algorithm Covariance Terms Reference Frame Reference Transformation Matrix Declination Adaptive Operation Adaptive EKF Enable Bit Automatic EKF Divergence Reset Control Bit Gyroscope Fade Control Bit Body Frame/Local Navigation Frame Bit Orientation Format Control Bit Magnetometer Disable Control Bit Gravity Removal Control Bit Linear Acceleration/Magnetic Disturbance Detection Calibration Gyroscopes Manual Bias Correction Manual Sensitivity Correction Linear Acceleration on Effect on Gyroscope Bias Accelerometers Manual Bias Correction Manual Sensitivity Correction Magnetometers Hard Iron Correction Soft Iron Correction Matrix Barometers Restoring Factory Calibration Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Example System Controls Global Commands Software Reset Automatic Self-Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management General-Purpose Registers Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU1/PCB PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
