Datasheet ADIS16334 (Analog Devices) - 2
DescriptionLow Profile, Six Degrees of Freedom Inertial Sensor
Pages / Page21 / 2 — ADIS16334* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionD
File Format / SizePDF / 496 Kb
ADIS16334* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADIS16334* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Customer Case Studies
• OrthAlign's KneeAlign® 2 System uses iSensor® MEMS
EVALUATION KITS
technology to provide surgical precision • ADIS16334 Daughter Board
Technical Articles
• ADIS1644X Flex Cable • MEMS Sensors: When GPS Is Not Enough • ADIS16IMU2 Breakout Board • MS-2151: Precision MEMS Sensors Enable New Navigation Applications • EVAL-ADIS Evaluation System
DOCUMENTATION DESIGN RESOURCES
• ADIS16334 Material Declaration
Application Notes
• PCN-PDN Information • AN-1146: ADIS16334 Mounting/Mechanical Design Guidelines and Examples • Quality And Reliability
Data Sheet
• Symbols and Footprints • ADIS16334: Low Profile Six Degree of Freedom Inertial Sensor Data Sheet
DISCUSSIONS
View all ADIS16334 EngineerZone Discussions.
SOFTWARE AND SYSTEMS REQUIREMENTS
• ADIS16400 IIO Inertial Measurement Unit Linux Driver
SAMPLE AND BUY
• ADIS16334 and ADIS16360/2/4/5/7 Evaluation Software Visit the product page to see pricing options. for the ADISUSB
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Gyroscopes Accelerometers Data Sampling and Processing Calibration User Interface SPI Interface Basic Operation Reading Sensor Data Burst Read Function Memory Map Output Data Registers Gyroscopes Accelerometers Internal Temperature Measurements Device Configuration Dual Memory Structure Digital Processing Configuration Sample Rate Input Clock Configuration Digital Filtering Dynamic Range Optimizing Accuracy Automatic Bias Correction Manual Bias Correction Restoring Factory Calibration Point-of-Percussion/Linear-g Compensation System Tools Global Commands General-Purpose I/O Data Ready I/O Indicator Self-Test Memory Test Status Device Identification Flash Memory Management Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example Applications Information ADIS16334/PCBZ Installation Mounting Approaches Outline Dimensions Ordering Guide
