Datasheet ADIS16362 (Analog Devices) - 2
DescriptionSix Degrees of Freedom Inertial Sensor
Pages / Page21 / 2 — ADIS16362* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 372 Kb
ADIS16362* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADIS16362* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Customer Case Studies
• OrthAlign's KneeAlign® 2 System uses iSensor® MEMS
EVALUATION KITS
technology to provide surgical precision • ADIS16IMU2 Breakout Board • EVAL-ADIS2 Evaluation System
DESIGN RESOURCES
• ADIS16362 Material Declaration
DOCUMENTATION
• PCN-PDN Information
Application Notes
• Quality And Reliability • AN-1041: iSensor® IMU Quick Start Guide and Bias • Symbols and Footprints Optimization Tips
Data Sheet DISCUSSIONS
• ADIS16362: Six Degrees of Freedom Inertial Sensor Data View all ADIS16362 EngineerZone Discussions. Sheet
User Guides SAMPLE AND BUY
• UG-363: ADISUSB User Guide Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS TECHNICAL SUPPORT
• ADIS16400 IIO Inertial Measurement Unit Linux Driver Submit a technical question or find your regional support • ADIS16400 IIO Inertial Measurement Unit Linux Driver number. • ADIS16334 and ADIS16360/2/4/5/7 Evaluation Software for the ADISUSB
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Operation Reading Sensor Data Device Configuration Memory Map Burst Read Data Collection Output Data Registers Calibration Manual Bias Calibration Gyroscope Automatic Bias Null Calibration Gyroscope Precision Automatic Bias Null Calibration Restoring Factory Calibration Linear Acceleration Bias Compensation (Gyroscope) Operational Control Global Commands Internal Sample Rate Power Management Sensor Bandwidth Digital Filtering Dynamic Range Input/Output Functions General-Purpose I/O Input Clock Configuration Data Ready I/O Indicator Auxiliary DAC Diagnostics Self-Test Memory Test Status Alarm Registers Product Identification Applications Information Installation/Handling Gyroscope Bias Optimization Input ADC Channel Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
