Datasheet ADXRS645 (Analog Devices) - 5
DescriptionHigh Temperature, Vibration Rejecting ±2000°/sec Gyroscope
Pages / Page11 / 5 — ADXRS645. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE …
File Format / SizePDF / 362 Kb
ADXRS645. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS. Parameter. Rating. Z-AXIS. RATE. AXIS. ESD CAUTION
ADXRS645 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 RATE SENSITIVE AXIS Parameter Rating Z-AXIS RATE AXIS ESD CAUTION
ADXRS645 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS Parameter Rating
The ADXRS645 produces a positive output voltage for clockwise Acceleration (Any Axis, 0.5 ms) rotation about the axis normal to the package lid, that is, Unpowered 10,000 g clockwise when looking at the package lid. Powered 10,000 g
Z-AXIS
VDD, AVCC −0.3 V to +6.6 V VRATIO AVCC ST1, ST2 AVCC Output Short-Circuit Duration (Any Pin to Indefinite Common)
002
RATE
Operating Temperature Range −55°C to +175°C
AXIS
1958- 1 Storage Temperature Range −65°C to +185°C Figure 2. RATEOUT Signal Increases with Clockwise Rotation Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
ESD CAUTION
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Drops onto hard surfaces can cause shocks of greater than 10,000 g and can exceed the absolute maximum rating of the device. Exercise care in handling to avoid damage. Rev. A | Page 4 of 10 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Supply Ratiometricity Range Extension Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide
