Datasheet ADXRS646 (Analog Devices) - 3
DescriptionHigh Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope
Pages / Page9 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/14618
File Format / SizePDF / 218 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/14618
1.3 Absolute maximum ratings. 1/ Acceleration (Any Axis, 0.5 ms): Unpowered ... 10,000 g Powered ... 10,000 g VDD, AVCC .. -0.3 V to +6.6 V VRATIO ... AVCC ST1, ST2 ... AVCC Output short circuit duration (Any pin to common) .. Indefinite Operating temperature range .. -65°C to +125°C Storage temperature range ... -65°C to 150°C 2. APPLICABLE DOCUMENTS There are no applicable documents. 3. REQUIREMENTS 3.1 Marking. Parts shall be permanently and legibly marked with the manufacturer’s part number as shown in 6.3 herein and as follows: A. Manufacturer’s name, CAGE code, or logo B. Pin 1 identifier C. ESDS identification (optional) 3.2 Unit container. The unit container shall be marked with the manufacturer’s part number and with items A and C (if applicable) above. 3.3 Electrical characteristics. The maximum and recommended operating conditions and electrical performance characteristics are as specified in 1.3, 1.4, and table I herein. 3.4 Design, construction, and physical dimension. The design, construction, and physical dimensions are as specified herein. 3.5 Diagrams. 3.5.1 Case outline. The case outline shall be as shown in 1.2.2 and figure 1. 3.5.2 Pin function description. The pin function description shall be as shown in figure 2. 3.5.3 Functional block diagram. The functional block diagram shall be as shown in figure 3. 1/ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/14618
REV PAGE 3 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/14618 REV
