Datasheet ADIS16136 (Analog Devices)
Description | ±450°/Sec Precision Angular Rate Sensor |
Pages / Page | 21 / 1 — ±450°/Sec Precision Angular Rate Sensor. Data Sheet. ADIS16136. FEATURES. … |
Revision | D |
File Format / Size | PDF / 490 Kb |
±450°/Sec Precision Angular Rate Sensor. Data Sheet. ADIS16136. FEATURES. GENERAL DESCRIPTION
±450°/Sec Precision Angular Rate Sensor Data Sheet ADIS16136 FEATURES GENERAL DESCRIPTION Digital gyroscope system, ±450°/sec measurement range
The ADIS16136 iSensor® is a high performance, digital gyroscope
In-run bias stability, 4°/hour
sensing system that operates autonomously and requires no
Autonomous operation and data collection
user configuration to produce accurate rate sensing data. It
No external configuration commands required
provides performance advantages with its low noise density,
Start-up time: 180 ms; sleep mode recovery: 2.5 ms
wide bandwidth, and excellent in-run bias stability, which enable
Factory calibrated sensitivity and bias
applications such as platform control, navigation, robotics, and
Calibration temperature range: −40°C to +70°C
medical instrumentation.
SPI-compatible serial interface
This sensor system combines industry leading iMEMS® technology
Wide bandwidth: 380 Hz
with signal conditioning that optimizes dynamic performance. The
Embedded temperature sensor
factory calibration characterizes the entire sensor signal chain for
Programmable operation and control
sensitivity and bias over a temperature range of −40°C to +70°C. As
Automatic and manual bias correction controls
a result, each ADIS16136 has its own unique correction formulas
Digital filters: Bartlett FIR, average/decimation
to produce accurate measurements upon instal ation. For some
Internal sample rate: up to 2048 SPS
systems, the factory calibration eliminates the need for system
Digital I/O: data ready, alarm indicator, general-purpose
level calibration and greatly simplifies it for others.
Alarms for condition monitoring Sleep mode for power management
The ADIS16136 provides data at rates of up to 2048 SPS and
Enable input sync operation
offers an averaging/decimation filter structure for optimizing
Single-supply operation: 4.75 V to 5.25 V
noise/bandwidth trade-offs. The serial peripheral interface (SPI)
2000 g shock survivability
and user register structure provide easy access to configuration
Operating temperature range: −40°C to +85°C
controls and calibrated sensor data for embedded processor
platforms. The 36 mm × 44 mm × 14 mm package provides four holes for
Precision instrumentation
simple mechanical attachment, using M2 (or 2-56 standard size)
Platform stabilization and control
machine screws along with a standard 24-pin, dual row, 1 mm
Industrial vehicle navigation
pitch connector that supports electrical attachment to a printed
Downhole instrumentation
circuit board (PCB) or cable system.
Robotics FUNCTIONAL BLOCK DIAGRAM DIO1 DIO2 DIO3 DIO4/CLKIN RST VDD SELF-TEST I/O ALARMS POWER GND MANAGEMENT MEMS SENSOR USER CONTROLLER CONTROL REGISTERS CS TEMP SENSOR SCLK SPI CLOCK CALIBRATION PORT DIN OUTPUT DATA DOUT REGISTERS FILTER
001
ADIS16136
10249- Figure 1.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION READING SENSOR DATA OUTPUT DATA REGISTERS Rotation Rate (Gyroscope) Internal Temperature DEVICE CONFIGURATION Dual Memory Structure USER REGISTERS DIGITAL PROCESSING CONFIGURATION INTERNAL SAMPLE RATE INPUT CLOCK CONFIGURATION DIGITAL FILTERING AVERAGING/DECIMATION FILTER CALIBRATION AUTOMATIC BIAS CORRECTION (AUTONULL) MANUAL BIAS CORRECTION Restoring Factory Calibration ALARMS STATIC ALARM USE DYNAMIC ALARM USE ALARM REPORTING Alarm Example SYSTEM CONTROLS GLOBAL COMMANDS Software Reset MEMORY MANAGEMENT Checksum Test GENERAL-PURPOSE INPUT/OUTPUT Data Ready Input/Output Indicator Example Input/Output Configuration AUTOMATIC SELF TEST POWER MANAGEMENT STATUS PRODUCT IDENTIFICATION APPLICATIONS INFORMATION POWER SUPPLY CONSIDERATIONS PROTOTYPE INTERFACE BOARD INSTALLATION TIPS PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
