Datasheet ADXRS624 (Analog Devices) - 7
Description | ±50°/s Yaw Rate Gyro |
Pages / Page | 13 / 7 — ADXRS624. TYPICAL PERFORMANCE CHARACTERISTICS. % 35. TION. TION A. U 20. … |
Revision | A |
File Format / Size | PDF / 596 Kb |
ADXRS624. TYPICAL PERFORMANCE CHARACTERISTICS. % 35. TION. TION A. U 20. F 20 O. T OF P. C 10. R E. PER. –10. RATEOUT (V). SENSITIVITY DRIFT (%)
ADXRS624 TYPICAL PERFORMANCE CHARACTERISTICS
N > 1000 for all typical performance plots, unless otherwise noted.
35 45 40 30 ) ) % % 35 ( ( 25 TION 30 TION A LA L U 20 25 PU OP PO 15 F 20 O T OF P T N 15 E EN C 10 C R E 10 P PER 5 5 0 0 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
004
0 2 4 6 8 1. 1. 1. 1. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 3. 3. 3. 3. 3. –8 –6 –4 –2 10 –10
007
RATEOUT (V)
08999-
08999- Figure 4. Null Output at 25°C (VRATIO = 5 V) Figure 7. Sensitivity Drift over Temperature
35 40 30 35 ) ) % % ( ( 30 25 TION TION A L A 25 L 20 PU PU 20 PO PO F 15 F O O T T 15 EN EN C 10 C 10 PER PER 5 5 0 0 0 30 25 20 15 10 05 05 10 15 20 25 30 10 05 00 95 90 85 80 75 70 65 60 55 50 45 40 35 30 0. 0. 0. 0. 0. 0.
008
–0. –0. –0. –0. –0. –0.
005
–2. –2. –2. –1. –1. –1. –1. –1. –1. –1. –1. –1. –1. –1. –1. –1. –1. RATEOUT TEMPCO (°/sec/°C)
08999-
ST1 Δ (V)
08999- Figure 5. Null Drift over Temperature (VRATIO = 5 V) Figure 8. ST1 Output Change at 25°C (VRATIO = 5 V)
30 40 35 25 ) ) % % ( ( 30 20 TION TION A A 25 L L PU PU 15 20 PO PO F F O O T T 15 10 EN EN C C 10 PER PER 5 5 0 0 00 25 50 75 00 25 50 75 00 25 50 75 00 25 50 30 35 40 45 50 55 60 65 70 75 80 85 90 95 00 05 10 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 2. 2. 2.
009
24. 24. 24. 24. 25. 25. 25. 25. 26. 26. 26. 26. 27. 27. 27.
006
ST2 Δ (V)
08999-
SENSITIVITY (mV/°/sec)
08999- Figure 6. Sensitivity at 25°C (VRATIO = 5 V) Figure 9. ST2 Output Change at 25°C (VRATIO = 5 V) Rev. A | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate-Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Calibrated Performance ADXRS624 and Supply Ratiometricity Null Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide Automotive Products
