Datasheet ADXRS622 (Analog Devices) - 5
Description±250°/sec Yaw Rate Gyroscope
Pages / Page13 / 5 — ADXRS622. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS. …
RevisionC
File Format / SizePDF / 355 Kb
ADXRS622. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS. Parameter. Rating. RATE. RATE OUT. AXIS. VCC = 5V. LONGITUDINAL. 4.75V
ADXRS622 ABSOLUTE MAXIMUM RATINGS Table 2 RATE SENSITIVE AXIS Parameter Rating RATE RATE OUT AXIS VCC = 5V LONGITUDINAL 4.75V
ADXRS622 ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS Parameter Rating
The ADXRS622 is a Z-axis rate-sensing device (also called a Acceleration (Any Axis, 0.5 ms) yaw rate-sensing device). It produces a positive going output Unpowered 2000 g voltage for clockwise rotation about the axis normal to the Powered 2000 g package top, that is, clockwise when looking down at the V , AV −0.3 V to +6.0 V package lid. DD CC V AV RATIO CC ST1, ST2 AV CC
RATE
Output Short-Circuit Duration Indefinite
RATE OUT AXIS
(Any Pin to Common)
VCC = 5V
Operating Temperature Range −55°C to +125°C
LONGITUDINAL 4.75V AXIS +
Storage Temperature Range −65°C to +150°C
V 7 RATIO/2 RATE IN 1 0.25V
Stresses above those listed under the Absolute Maximum
A B C D E F G A1
002 Ratings may cause permanent damage to the device. This is a
LATERAL AXIS GND
07754- stress rating only; functional operation of the device at these or Figure 2. RATEOUT Signal Increases with Clockwise Rotation any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute
ESD CAUTION
maximum rating conditions for extended periods may affect device reliability. Drops onto hard surfaces can cause shocks of >2000 g and can exceed the absolute maximum rating of the device. Exercise care during handling to avoid damage. Rev. C | Page 4 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Calibrated Performance ADXRS622 and Supply Ratiometricity Null Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide Automotive Products
