Datasheet ADXRS622 (Analog Devices) - 7
Description±250°/sec Yaw Rate Gyroscope
Pages / Page13 / 7 — ADXRS622. TYPICAL PERFORMANCE CHARACTERISTICS. TION A. TION. U 12. U 20. …
RevisionC
File Format / SizePDF / 355 Kb
ADXRS622. TYPICAL PERFORMANCE CHARACTERISTICS. TION A. TION. U 12. U 20. PO 10. F O 15. RCE. E P. –10. (V). PERCENT CHANGE FROM 25°C. L 25. P 40
ADXRS622 TYPICAL PERFORMANCE CHARACTERISTICS TION A TION U 12 U 20 PO 10 F O 15 RCE E P –10 (V) PERCENT CHANGE FROM 25°C L 25 P 40
N > 1000 for all typical performance plots, unless otherwise noted.
20 35 18 30 16 14 25 TION A TION L A U 12 L P U 20 P PO 10 F PO O F O 15 8 NT NT RCE 6 10 E RCE P E P 4 5 2 0 0 0 2 4 6 8 20 25 30 35 40 45 50 55 60 65 70 75 80 10
004
–10 –8 –6 –4 –2 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2.
007
07754- 07754- Figure 4. Null Output at 25°C (V Figure 7. Sensitivity Drift over Temperature RATIO = 5 V)
70 40 35 60 30 50 TION TION A A L L 25 U U P 40 P PO PO 20 F F O O 30 NT NT 15 RCE 20 RCE E E P 10 P 10 5 0 0 0 50 –50 100 150 200 250 300 350 400 450 425 400 –400 –350 –300 –250 –200 –150 –100
005
–675 –650 –625 –600 –575 –550 –525 –500 –475 –375
008
mV DRIFT FROM 25°C (mV)
07754- 07754- Figure 5. Null Drift over Temperature (VRATIO = 5 V) Figure 8. ST1 Output Change at 25°C (VRATIO = 5 V)
30 40 35 25 30 TION TION A 20 A L L U 25 U P P PO 15 PO F 20 F O O NT NT 15 10 RCE RCE E E P 10 P 5 5 0 0 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 0 6. 6. 6. 6. 6. 6. 6. 7. 7. 7. 7. 7. 7. 7. 7. 7. 25
006
375 400 425 450 475 500 525 550 575 60 6 650 675
009
(mV/°/sec)
07754-
(mV)
07754- Figure 6. Sensitivity at 25°C (VRATIO = 5 V) Figure 9. ST2 Output Change at 25°C (VRATIO = 5 V) Rev. C | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Calibrated Performance ADXRS622 and Supply Ratiometricity Null Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide Automotive Products
