Datasheet ADXRS620 (Analog Devices) - 7
Description±300°/sec Yaw Rate Gyro
Pages / Page13 / 7 — ADXRS620. TYPICAL PERFORMANCE CHARACTERISTICS. TION. OF P. –10. DRIFT …
File Format / SizePDF / 558 Kb
ADXRS620. TYPICAL PERFORMANCE CHARACTERISTICS. TION. OF P. –10. DRIFT (%). RATE OUT (V). –0.5. –0.4. –0.3. –0.2 –0.1. 0.1. 0.2. 0.3. 0.4. 0.5
ADXRS620 TYPICAL PERFORMANCE CHARACTERISTICS TION OF P –10 DRIFT (%) RATE OUT (V) –0.5 –0.4 –0.3 –0.2 –0.1 0.1 0.2 0.3 0.4 0.5
N > 1000 for all typical performance plots, unless otherwise noted.
20 30 18 ) ) % 25 % ( 16 ( TION 14 TION 20 LA LA U 12 U OP OP 10 15 OF P OF P 8 GE GE TA TA 10 6 N N E E C C R 4 R E E P 5 P 2 0 0
007
20 25 30 35 40 45 50 55 60 65 70 75 80 –10 –8 –6 –4 –2 0 2 4 6 8 10
004
2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. DRIFT (%)
08887-
RATE OUT (V)
08887- Figure 4. Null Output at 25°C (V Figure 7. Sensitivity Drift over Temperature RATIO = 5 V)
45 35 40 ) ) 30 % % ( 35 ( TION 25 TION 30 LA LA U U 20 OP 25 OP OF P 20 OF P 15 GE GE 15 TA TA N N 10 E E C 10 C R R E E P P 5 5 0 0 –0.5 –0.4 –0.3 –0.2 –0.1 0 0.1 0.2 0.3 0.4 0.5 –650 –610 –570 –530 –490 –450 –410 –370 –330 –290 –250
008 005
(°/sec°/C) ST1 Δ (mV)
08887- 08887- Figure 5. Null Drift over Temperature (V Figure 8. ST1 Output Change at 25°C (V RATIO = 5 V) RATIO = 5 V)
16 40 14 35 ) % ( 12 30 TION 10 LA 25 TION U LA OP U 8 20 OP OF P 6 GE 15 OF P % TA N 4 E 10 C R E P 2 5 0 0
006
5.5 5.6 5.7 5.8 5.9 6 6.1 6.2 6.3 6.4 6.5
009
250 290 330 370 410 450 490 530 570 610 650 SENSITIVITY (mV/°/sec)
08887-
ST2 Δ (mV)
08887- Figure 6. Sensitivity at 25°C (VRATIO = 5 V) Figure 9. ST2 Output Change at 25°C (VRATIO = 5 V) Rev. B | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Calibrated Performance ADXRS620 and Supply Ratiometricity Null Adjustment Self-Test Function Continuous Self-Test Outline Dimensions Ordering Guide Automotive Products
