Datasheet ADIS16060 (Analog Devices) - 5
DescriptionWide Bandwidth Yaw Rate Gyroscope with SPI
Pages / Page13 / 5 — ADIS16060. Data Sheet. Parameter. Test Conditions/Comments. Min1. Typ. …
File Format / SizePDF / 309 Kb
ADIS16060. Data Sheet. Parameter. Test Conditions/Comments. Min1. Typ. Max. Unit
ADIS16060 Data Sheet Parameter Test Conditions/Comments Min1 Typ Max Unit
link to page 5
POWER SUPPLY All at TA = −40°C to +85°C VCC 4.75 5 5.25 V VCC Quiescent Supply Current VCC @ 5 V, 50 kSPS sample rate 4.3 6.5 mA Power Dissipation VCC @ 5 V, 50 kSPS sample rate 22 33 mW TEMPERATURE RANGE Operation −40 +105 °C 1 All minimum and maximum specifications are guaranteed. Typical specifications are neither tested nor guaranteed. 2 Dynamic range is the maximum ful -scale measurement range possible, including output swing range, initial offset, sensitivity, offset drift, and sensitivity drift at 5 V supply. 3 Defined as the output change from ambient to maximum temperature, or ambient to minimum temperature. 4 Frequency at which the response is 3 dB down from dc response. Bandwidth = 1/(2 × π × 200 kΩ × COUT). For COUT = 0.01 μF, bandwidth = 80 Hz. 5 Self-test response varies with temperature. Rev. A | Page 4 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Analog-to-Digital Converter Input Rate Sensitive Axis Basic Operation Serial Peripheral Interface (SPI) Selecting Output Data Output Data Access Output Data Formatting ADC Conversion Applications Information Supply And Common Considerations Setting Bandwidth Increasing Measurement Range Dynamic Digital Sensitivity Scaling Temperature Measurements Self-Test Function Outline Dimensions Ordering Guide
