Datasheet ADIS16060 (Analog Devices) - 7
DescriptionWide Bandwidth Yaw Rate Gyroscope with SPI
Pages / Page13 / 7 — ADIS16060. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. …
RevisionA
File Format / SizePDF / 309 Kb
ADIS16060. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION
ADIS16060 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings
Table 3.
may cause permanent damage to the device. This is a stress
Parameter Rating
rating only; functional operation of the device at these or any Acceleration (Any Axis, Unpowered, 0.5 ms) 2000 g other conditions above those indicated in the operational Acceleration (Any Axis, Powered, 0.5 ms) 2000 g section of this specification is not implied. Exposure to absolute VCC to GND −0.3 V to +6.0 V maximum rating conditions for extended periods may affect VCC to GND −0.3 V to VCC + 0.3 V device reliability. Analog Input Voltage to GND −0.3 V to VCC + 0.3 V Drops onto hard surfaces can cause shocks of greater than Digital Input Voltage to GND −0.3 V to +7.0 V 2000 g and exceed the absolute maximum rating of the device. Digital Output Voltage to GND −0.3 V to VCC + 0.3 V Care should be exercised in handling the device to avoid damage. Operating Temperature Range −40°C to +105°C Storage Temperature Range −65°C to +150°C
ESD CAUTION
Rev. A | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Analog-to-Digital Converter Input Rate Sensitive Axis Basic Operation Serial Peripheral Interface (SPI) Selecting Output Data Output Data Access Output Data Formatting ADC Conversion Applications Information Supply And Common Considerations Setting Bandwidth Increasing Measurement Range Dynamic Digital Sensitivity Scaling Temperature Measurements Self-Test Function Outline Dimensions Ordering Guide
