Datasheet LT1249 (Linear Technology) - 3
ManufacturerLinear Technology
DescriptionPower Factor Controller
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
RevisionS
File Format / SizePDF / 203 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the operating temperature
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the operating temperature
LT1249
denotes specifications which apply over the operating temperature range, otherwise specifications are at TA = 25
C. Maximum operating voltage (VMAX) = 25V, VCC = 18V, IAC = 100
µ
A, CAOUT = 3.5V, VAOUT = 5V, no load on any outputs, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Reference
Reference Output Voltage TA = 25°C, Measured at VSENSE Pin 7.39 7.5 7.6 V Reference Output Voltage Worst Case All Line, Temperature ● 7.32 7.5 7.68 V Reference Output Voltage Line Regulation VLOCKOUT < VCC < VMAX ● – 20 5 20 mV
Multiplier
Multiplier Output Current IAC = 100µA, VAOUT = 5V 35 µA Multiplier Output Current Offset RAC = 1M from IAC to GND ● – 0.05 – 0.5 µA Multiplier Max Output Current (IM(MAX)) IAC = 450µA, VAOUT = 7V (Note 2) ● – 375 – 250 – 150 µA Multiplier Max Output Voltage (IM(MAX) • RMOUT) IAC = 450µA, VAOUT = 7V (Note 2) ● – 1.25 – 1.1 – 0.96 V Multiplier Gain Constant (Note 3) 0.035 V–2 IAC Input Resistance IAC from 50µA to 1mA 15 32 50 kΩ
Oscillator
Oscillator Frequency ● 75 100 125 kHz Control Pin (CAOUT) Threshold Duty Cycle = 0 ● 1.3 1.8 2.3 V Synchronization Frequency Range Synchronizing Pulse Low ≤ 0.35V on CAOUT ● 127 160 kHz
Gate Driver
Max GTDR Output Voltage 0mA Load, 18V < VCC < VMAX (Note 4) ● 12 15 17.5 V GTDR Output High – 200mA Load, 11.5V ≤ VCC ≤ 15V ● VCC – 3.0 V GTDR Output Low (Device Unpowered) VCC = 0V, 50mA Load (Sinking) ● 0.9 1.5 V GTDR Output Low (Device Active) 200mA Load (Sinking) ● 0.5 1 V Peak GTDR Current 10nF from GTDR to GND 1.5 A GTDR Rise and Fall Time 1nF from GTDR to GND 25 ns GTDR Max Duty Cycle 90 96 %
Note 1:
Absolute Maximum Ratings are those values beyond which the life I
Note 3:
Multiplier Gain Constant: K = M of a device may be impaired. IAC (VAOUT – 1.5)2
Note 2:
Current amplifier is in linear mode with 0V input common mode.
Note 4:
Maximum GTDR output voltage is internally clamped for higher VCC voltages.
W U TYPICAL PERFORMANCE CHARACTERISTICS Voltage Amplifier Open-Loop Transconductance of Gain and Phase Current Amplifier
100 0 400 20 θ 350 0 80 –20 gm GAIN 300 –20 µmho) 60 –40 PHASE (DEG) PHASE (DEG) 250 –40 40 –60 200 –60 GAIN (dB) 150 –80 20 –80 PHASE 100 –100 TRANSCONDUCTANCE ( 0 –100 50 –120 –20 –120 0 –140 10 100 1k 10k 100k 1M 10M 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) 1249 G01 1249 G02 3
