Datasheet CA3140, CA3140A (Intersil) - 4
ManufacturerIntersil
Description4.5MHz, BiMOS Operational Amplifier with MOSFET Input/Bipolar Output
Pages / Page23 / 4 — CA3140, CA3140A. Electrical Specifications. (Continued). CA3140. CA3140A. …
Revision2017-12-07
CA3140, CA3140A. Electrical Specifications. (Continued). CA3140. CA3140A. PARAMETER. SYMBOL. MIN. TYP. MAX. UNITS. TYPICAL VALUES
CA3140, CA3140A Electrical Specifications (Continued) CA3140 CA3140A PARAMETER SYMBOL MIN TYP MAX UNITS TYPICAL VALUES
For Equipment Design, at VSUPPLY = ±15V, TA = 25oC, Unless Otherwise Specified
(Continued) CA3140 CA3140A PARAMETER SYMBOL MIN TYP MAX MIN TYP MAX UNITS
Large Signal Voltage Gain (Note 3) AOL 20 100 - 20 100 - kV/V (See Figures 6, 29) 86 100 - 86 100 - dB Common Mode Rejection Ratio CMRR - 32 320 - 32 320 µV/V (See Figure 34) 70 90 - 70 90 - dB Common Mode Input Voltage Range (See Figure 8) VICR -15 -15.5 to +12.5 11 -15 -15.5 to +12.5 12 V Power-Supply Rejection Ratio, PSRR - 100 150 - 100 150 µV/V ∆VIO/∆VS (See Figure 36) 76 80 - 76 80 - dB Max Output Voltage (Note 4) VOM+ +12 13 - +12 13 - V (See Figures 2, 8) VOM- -14 -14.4 - -14 -14.4 - V Supply Current (See Figure 32) I+ - 4 6 - 4 6 mA Device Dissipation PD - 120 180 - 120 180 mW Input Offset Voltage Temperature Drift ∆VIO/∆T - 8 - - 6 - µV/oC NOTES: 3. At VO = 26VP-P, +12V, -14V and RL = 2kΩ. 4. At RL = 2kΩ.
For Design Guidance At V+ = 5V, V- = 0V, TA = 25oC
TYPICAL VALUES PARAMETER SYMBOL CA3140 CA3140A UNITS
Input Offset Voltage |VIO| 5 2 mV Input Offset Current |IIO| 0.1 0.1 pA Input Current II 2 2 pA Input Resistance RI 1 1 TΩ Large Signal Voltage Gain (See Figures 6, 29) AOL 100 100 kV/V 100 100 dB Common Mode Rejection Ratio CMRR 32 32 µV/V 90 90 dB Common Mode Input Voltage Range (See Figure 8) VICR -0.5 -0.5 V 2.6 2.6 V Power Supply Rejection Ratio PSRR 100 100 µV/V ∆VIO/∆VS 80 80 dB Maximum Output Voltage (See Figures 2, 8) VOM+ 3 3 V VOM- 0.13 0.13 V Maximum Output Current: Source IOM+ 10 10 mA Sink IOM- 1 1 mA Slew Rate (See Figure 31) SR 7 7 V/µs Gain-Bandwidth Product (See Figure 30) fT 3.7 3.7 MHz Supply Current (See Figure 32) I+ 1.6 1.6 mA Device Dissipation PD 8 8 mW Sink Current from Terminal 8 to Terminal 4 to Swing Output Low 200 200 µA 4 FN957.10 July 11, 2005
