Datasheet MIC4680 (Microchip) - 9
ManufacturerMicrochip
Description1A 200kHz SuperSwitcher Buck Regulator
Pages / Page15 / 9 — Micrel, Inc. MIC4680 Functional Description. A higher feedback voltage …
Revision11-05-2015
File Format / SizePDF / 906 Kb
Micrel, Inc. MIC4680 Functional Description. A higher feedback voltage increases the error amplifier
Micrel, Inc MIC4680 Functional Description A higher feedback voltage increases the error amplifier
output voltage. A higher error amplifier voltage
(comparator inverting input) causes the comparator to
detect only the peaks of the sawtooth, reducing the duty
cycle of the comparator output. A lower feedback voltage
increases the duty cycle. The MIC4680 uses a voltagemode control architecture. The MIC4680 is a variable duty cycle switch-mode
regulator with an internal power switch. Refer to the
block diagrams.
Supply Voltage
The MIC4680 operates from a +4V to +34V unregulated
input. Highest efficiency operation is from a supply
voltage around +15V. See the efficiency curves. Output Switching
When the internal switch is on, an increasing current
flows from the supply VIN, through external storage
inductor L1, to output capacitor COUT and the load.
Energy is stored in the inductor as the current increases
with time.
When the internal switch is turned off, the collapse of the
magnetic field in L1 forces current to flow through fast
recovery diode D1, charging COUT. Enable/Shutdown
The shutdown (SHDN) input is TTL compatible. Ground
the input if unused. A logic-low enables the regulator. A
logic-high shuts down the internal regulator which
reduces the current to typically 1.5µA when VSHDN = VIN
= 12V and 30µA when VSHDN = 5V. See “Shutdown Input
Behavior: Shutdown Hysteresis.”
Feedback
Fixed-voltage versions of the regulator have an internal
resistive divider from the feedback (FB) pin. Connect FB
directly to the output voltage.
Adjustable versions require an external resistive voltage
divider from the output voltage to ground, center tapped
to the FB pin. See Figure 6b for recommended resistor
values Output Capacitor
External output capacitor COUT provides stabilization and
reduces ripple. See “Bode Plots” for additional
information.
Return Paths
During the on portion of the cycle, the output capacitor
and load currents return to the supply ground. During the
off portion of the cycle, current is being supplied to the
output capacitor and load by storage inductor L1, which
means that D1 is part of the high-current return path. Duty Cycle Control
A fixed-gain error amplifier compares the feedback
signal with a 1.23V bandgap voltage reference. The
resulting error amplifier output voltage is compared to a
200kHz sawtooth waveform to produce a voltage
controlled variable duty cycle output. March 2008 9 M9999-032808
