Datasheet LT8364 (Analog Devices) - 2
DescriptionLow IQ Boost/SEPIC/Inverting Converter with 4A, 60V Switch
Pages / Page30 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION http://www.linear.com/product/LT8364#orderinfo
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION http://www.linear.com/product/LT8364#orderinfo
LT8364
SW .. 60V FBX ... ±4V VIN, EN/UVLO .. 60V Operating Junction Temperature (Note 3) BIAS .. 40V LT8364E, LT8364I ..–40°C to 125°C EN/UVLO Pin Above VIN Pin, SYNC... 6V LT8364H ...–40°C to 150°C INTVCC ...(Note 2) Storage Temperature Range ...–65°C to 150°C VC ... 4V
PIN CONFIGURATION
TOP VIEW TOP VIEW EN/UVLO 1 16 SW1 NC 1 12 SW1 EN/UVLO 2 11 SW2 V 3 IN 14 SW2 17 PGND, VIN 3 10 SYNC/MODE INTV 5 13 CC 12 SYNC/MODE NC 6 GND 11 SS GND INTVCC 4 9 SS BIAS 7 10 RT V 8 BIAS 5 8 RT C 9 FBX MSE PACKAGE VC 6 7 FBX VARIATION: MSE16 (12) 16-LEAD PLASTIC MSOP DE PACKAGE θJA = 45°C/W, θJC = 10°C/W 12-LEAD (4mm × 3mm) PLASTIC DFN EXPOSED PAD (PIN 17) IS PGND AND GND, MUST BE SOLDERED TO PCB θJA = 43°C/W, θJC = 5.5°C/W EXPOSED PAD (PIN 13) IS PGND AND GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION http://www.linear.com/product/LT8364#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT8364EMSE#PBF LT8364EMSE#TRPBF 8364 16-Lead Plastic MSOP with 4 Pins Removed –40°C to 125°C LT8364IMSE#PBF LT8364IMSE#TRPBF 8364 16-Lead Plastic MSOP with 4 Pins Removed –40°C to 125°C LT8364HMSE#PBF LT8364HMSE#TRPBF 8364 16-Lead Plastic MSOP with 4 Pins Removed –40°C to 150°C LT8364EDE#PBF LT8364EDE#TRPBF 8364 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT8364IDE#PBF LT8364IDE#TRPBF 8364 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT8364HDE#PBF LT8364HDE#TRPBF 8364 12-Lead (4mm × 3mm) Plastic DFN –40°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 8364f 2 For more information www.linear.com/LT8364 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
