Datasheet AVM-273HP+ - Full Version (Mini-Circuits) - 10
ManufacturerMini-Circuits
DescriptionWideband, Microwave 0.5W Monolithic Amplifier 50Ω 13 to 26.5 GHz
Pages / Page24 / 10 — MMIC Amplifier. AVM-273HP+. Definitions:. Input. Output. 1dB. IP-3. …
MMIC Amplifier. AVM-273HP+. Definitions:. Input. Output. 1dB. IP-3. Noise. FREQ. Gain. Isolation. Return. Stability. Comp. Figure. Loss. (GHz). (dB)
MMIC Amplifier AVM-273HP+ Definitions: Input Output 1dB IP-3 Noise FREQ Gain Isolation Return Stability Comp Figure Loss (GHz) (dB)
Typical Performance Data
Definitions:
Input Return Loss = -S11 (dB) Gain(Power Gain) = S21 (dB) Reverse Isolation = -S12 (dB) Output Return Loss = -S22 (dB) TEST CONDITIONS: Vd = 5.25V, Id = 597.91mA @ Temperature = +25°C
Input Output 1dB IP-3 Noise FREQ Gain Isolation Return Return Stability Comp. Output Figure Loss Loss Output (GHz) (dB) (dB) (dB) (dB) K Measure (dBm) (dBm) (dB)
12.0 12.29 54.45 16.02 4.70 41.24 0.68 26.53 18.03 10.35 12.2 12.64 52.83 16.11 5.14 34.50 0.71 27.70 18.93 10.18 12.4 12.87 54.08 16.13 5.67 40.85 0.75 27.25 19.57 10.21 12.6 12.94 51.83 16.06 6.21 32.66 0.78 28.94 20.18 10.10 12.8 13.02 52.35 16.22 6.82 35.82 0.81 29.05 20.63 10.05 13.0 13.02 53.17 16.44 7.50 40.91 0.84 30.02 21.36 10.08 13.2 13.05 53.61 17.17 8.38 44.78 0.87 30.58 21.83 9.99 13.4 13.05 54.34 17.49 9.21 50.17 0.89 30.56 22.30 9.96 13.6 13.05 55.47 16.79 10.06 58.31 0.92 31.65 22.36 9.87 13.8 13.09 55.61 17.23 11.20 60.61 0.94 31.47 22.85 9.68 14.0 13.13 55.25 17.29 12.37 59.01 0.96 32.39 23.00 9.72 14.5 13.35 56.26 17.82 15.85 66.89 0.99 32.91 24.32 9.61 15.0 13.68 58.12 18.38 19.55 81.23 1.00 33.10 25.00 9.37 15.5 14.09 59.30 18.22 23.89 89.35 1.01 33.62 25.33 9.26 16.0 14.49 61.06 18.27 30.53 104.76 1.01 33.99 25.85 9.02 17.0 14.97 55.64 20.76 23.74 53.34 1.00 33.38 26.07 8.84 17.5 15.11 72.23 26.01 16.17 349.53 0.98 33.40 25.58 8.86 18.0 15.66 63.79 27.67 15.04 123.23 0.97 33.42 26.99 8.74 18.5 15.76 55.70 19.18 12.98 46.61 0.96 33.19 26.48 8.48 19.0 15.36 55.02 15.08 14.50 44.90 0.99 32.26 26.36 8.56 19.5 15.73 57.48 11.82 15.28 55.47 1.03 32.19 26.42 8.55 20.0 15.59 59.98 10.20 14.35 72.20 1.06 32.21 26.49 8.86 20.5 14.96 60.48 8.31 15.31 78.05 1.11 31.64 26.54 9.04 21.0 14.52 64.68 7.68 14.88 129.16 1.13 31.35 26.62 9.16 21.5 14.12 60.89 7.06 14.57 84.56 1.15 31.09 26.62 9.20 22.0 13.94 61.18 7.02 12.72 87.42 1.13 30.74 26.20 9.07 22.5 13.73 59.71 6.85 11.84 73.79 1.13 31.24 26.25 8.65 23.0 13.78 59.51 7.26 11.90 73.47 1.11 31.53 26.33 8.44 23.5 13.80 53.50 7.85 11.90 37.74 1.09 30.88 26.26 8.21 24.0 14.26 50.91 9.51 11.70 28.05 1.04 30.51 25.63 7.82 24.5 14.73 45.30 11.30 12.95 14.82 1.02 30.29 25.89 7.25 25.0 14.89 42.67 11.77 12.90 10.92 1.01 30.04 25.12 7.29 25.4 14.51 40.43 14.02 12.03 8.97 0.97 30.82 25.73 6.98 25.6 14.02 41.96 14.67 11.62 11.28 0.96 30.28 25.84 7.08 25.8 13.98 42.60 16.19 11.56 12.30 0.95 30.62 25.56 7.09 26.0 13.66 40.50 15.15 10.52 9.78 0.93 30.82 25.08 7.21 26.2 13.98 43.61 15.52 11.03 13.62 0.94 30.92 25.27 7.11 26.4 13.90 41.05 12.78 10.53 9.92 0.95 30.88 24.79 7.38 26.5 13.92 41.08 11.62 10.24 9.71 0.96 30.56 24.81 7.38 REV. OR AVM-273HP+ 4/3/2014 Page 3 of 9 Document Outline AVM-273HP+ Data Sheet View Data View Graphs Case Style PCB Layout Eval Board Enviromental Ratings
